| Home > Help Needed / General Tech Chat > fly wheel well stuck | |||||||
![]() 183 Posts Member #: 1391 Advanced Member sheffield south yorkshire |
20th Feb, 2007 at 08:53:46pm
Once again my turbo buddys, my turbo build has gone to sh*t. tryed to get the fly wheel off and it has stuck, so stuck that it has killed 2 ont just one but 2 fly wheel pullers!!!!!!!
70 mph oil feed pipe pop!!!!! |
20th Feb, 2007 at 08:57:05pm
this is not a poll i need help!!!!!!!!!!! 70 mph oil feed pipe pop!!!!! |
20th Feb, 2007 at 08:57:37pm
heat and a puller at the same time? worked for me 998! My build thread..
20th Feb, 2007 at 09:47:25pm
leave the puller on really tight overnight. Keep giving the centre bolt a belt with a lump hammer too.
20th Feb, 2007 at 10:00:46pm
do what iain says ALSO ................
20th Feb, 2007 at 11:34:40pm
Also try hitting the back of the flywheel through the starter motor hole, while the puller is on, and tight. Keep rotating the flywheel and hit it in different spots.
21st Feb, 2007 at 12:20:38am
yer stand back!!
My build thread..
21st Feb, 2007 at 12:58:26am
Yep had the same problem, did as Turbo Phil says and tapped the back of the flywheel assembly through the starter motor hole, rotating it and hitting it to give the whole thing equal wallops!
21st Feb, 2007 at 07:34:26am
Beating the flywheel through the starter aperture is a shitty idea. It bends the flywheel. Especially stupid with an ultralight one. On 13th Jul, 2012 Ben H said:
21st Feb, 2007 at 08:33:01am
i've hit my ultra light flywheel many times and had it checked, and its fine.
21st Feb, 2007 at 08:36:47am
On 21st of Feb, 2007 at 07:34am Vegard said:
Beating the flywheel through the starter aperture is a shitty idea. It bends the flywheel. Especially stupid with an ultralight one. It matters not if it's the standard Verto item that's destined for the scrap pile anyway.
21st Feb, 2007 at 08:43:39am
if its a standard flywheel, hit it with a sledge hammer throught the starter hole, if that does not work, find a bigger hammer |
21st Feb, 2007 at 09:12:44am
Heat is my new best friend. Nothing stands in my way now with the blow torch in hand. On 7th Nov, 2008 Nic said:
21st Feb, 2007 at 10:24:05am
Phil, you could bend the crank as well, even if the flywheel is destined for the scrappy. On 13th Jul, 2012 Ben H said:
21st Feb, 2007 at 02:07:33pm
Ive always found a bit of heat, with a heat gun helps, if your in a rush!
![]() 549 Posts Member #: 1347 Post Whore Croydon (South London) |
21st Feb, 2007 at 02:59:42pm
careful if you smack it through the starter hole, ive chipped flywheels like that before. For me that methods never worked, leaving the puller on overnight has tho. Good luck Edited by AL on 21st Feb, 2007. |
21st Feb, 2007 at 04:41:51pm
thanks guys i think its a combo of all your help that will see me to the end of this .
180 Posts Member #: 591 Advanced Member Rugeley, Midlands, England |
21st Feb, 2007 at 05:35:28pm
I used a mixture of heat and loctite freezing freeway type spray on the crank, came off like a very slippery thing on something more slippery, was very supprised, oh well maybe my a+ base engine for turbo will offer me some problems. |
21st Feb, 2007 at 08:48:36pm
just to let you all know the f**k*r has come off with a lot of heat and a quick thermal shock (Thanks Dad!). but id also like to thankeveryone who posted me help! your advice was a great help!!!!! :cool: 70 mph oil feed pipe pop!!!!! |
