Home > Help Needed / General Tech Chat > Dashpot springs
Just wondering what the recommended was for a high boost turbo
i.e. 14psi upwards.
I'm running a standard one at the minute and was wondering if it's also contributing to my misfire.
So what you all running?
Avonbar highboost one
Turbo Shed
Member #: 30
Epsom, Surrey
i ran the standard one for years, then got the high boost one (think its a green one or montego one) and made no difference at all, still have a bit of a splutter off boost.
Dangerous
Member #: 417
I got 2 std ones in
Dangerous, thats what was suggested to me, something i like the sound of since i already have another spare spring at home *smiley*
Dangerous
Member #: 417
Think it is a benross trick,I did it as the oil kept disappearing too quick which must be caused by the piston going up too quick
slater
Member #: 1291
Suffolk / Birmingham
good tip, i get a bit of a miss when changing gear and coming back on the throttle hard so il give it a go asap!
Carl
Member #: 95
liverpool-on-sea
i use an avonbar high boost one
Star Mag
Member #: 375
Leicestershire
I have tried both methods and still get the odd splutter as if the dashpot is firing up! go for the cheap option!
turbo hogster
Member #: 178
stowmaket suffolk
i just use sae 80 weight gear oil that works fine
i use two springs iain more than up to the job
Pretty sure I used 2 springs too....although not sure what colours.
It was 2 different colours though, I do remember that
Ive got a spring from a N/A carb would that work the same, or are they not as strong?
there are 3 springs.
n/a, yellow and green I think ? turbo'd metro and montego use stiffer springs
