| Home > Help Needed / General Tech Chat > shot wheel bearing??? | |||||||
24th Feb, 2007 at 04:19:20pm
The passenger side wheel bearing appears to be making a slight rumbling noise, which I know is a sign the wheel bearing is not right.
Edited by minimole23 on 24th Feb, 2007. On 7th Oct, 2010 5haneJ said:
![]() 549 Posts Member #: 1347 Post Whore Croydon (South London) |
24th Feb, 2007 at 04:30:08pm
could it be a cv joint? Does it rumble more or less when you round bends? |
24th Feb, 2007 at 04:49:58pm
hope this helps.
24th Feb, 2007 at 04:51:48pm
sounds like wheel bearing |
24th Feb, 2007 at 07:05:11pm
I have had this ...... ultimately the only reason I found it was when I had a bearing failure on the North Circular Road in London at rush hour!!!
24th Feb, 2007 at 08:54:59pm
Thanks for that, i'll get that fixed asap. the noise has got considerably worse in 50 miles, better stop driving it and fix it.
25th Feb, 2007 at 01:01:39am
sounds like a bearing. is the bearing tight? if so try packing it with grease first as iv changed rumbling bearings that have just turned out to be unworn and dry, ie, no grease left in them |
25th Feb, 2007 at 01:41:53am
Always check the CV, driv flange, and hub for wear (from a spinning outer race) before fitting the new parts. Otherwise you'll be doing it again after a short time. :) On 17th Nov, 2014 Tom Fenton said:
