| Home > Help Needed / General Tech Chat > fuel filter | |||||||
93 Posts Member #: 1212 Advanced Member braintree, essex |
26th Feb, 2007 at 08:12:49pm
i have a 10psi max fuel filter. is it ok to run it between the carb and the regulator? i spoke to avonbar as i was worried that it wouldnt be up for running in between the pump and regulator and Ian said use it between the carb and regulator. |
![]() 508 Posts Member #: 487 Post Whore westbury, wiltshire |
26th Feb, 2007 at 08:15:56pm
if you run it in between the carb and regulator you will still see over 10psi of fuel pressure if running more then 7psi of boost, the only place there is very little pressure is in between the tank and pump "Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
26th Feb, 2007 at 08:44:27pm
Yep most use them between tank and pump, better for pump too to filter before it. -MINI CLUBMAN 1380 TURBO- |
26th Feb, 2007 at 09:10:53pm
All very true but make sure you check it regularly .... if it blocks you may end up really lean on a full power run and then you'll be catching the bus .... probably to the piston suppliers!!
26th Feb, 2007 at 10:25:04pm
On 26th of Feb, 2007 at 08:44pm T3Tone said:
Yep most use them between tank and pump, better for pump too to filter before it. Unless the filter is quite large and specifically designed to be run in front of an efi pump, I would NOT use it before the pump. It will starve the pump causing cavitation which will cause pump and running problems. EFI pumps must have a good unrestricted fuel supply. So that will mean a big free flowing filter. If its after the pump, whilst it still needs to flow well, it isnt as important, because the pump will be able to pump through it just fine. 9.85 @ 145mph
26th Feb, 2007 at 10:32:43pm
Although I'd like to have a filter in front of my fuel pump I couldn't find any that looked as if they'd flow enough to go on the suction side of the pump, so I use a filter from a VW Polo between reg and carb, it is ideal as it has the right size tails and is a metal cased filter.
26th Feb, 2007 at 11:19:25pm
On 26th of Feb, 2007 at 09:10pm RogerM said:
then you'll be catching the bus .... probably to the piston suppliers!! A quote like that sounds like something that the great sheriff John Bunnell would say |
27th Feb, 2007 at 10:58:57am
ok so what filter is best for me if im using an spi tank? Edited by mickeyturbo on 27th Feb, 2007. |
27th Feb, 2007 at 07:27:10pm
On 26th of Feb, 2007 at 10:32pm Tom Fenton said:
Although I'd like to have a filter in front of my fuel pump I couldn't find any that looked as if they'd flow enough to go on the suction side of the pump, so I use a filter from a VW Polo between reg and carb, it is ideal as it has the right size tails and is a metal cased filter. search ebay for some Porsche fitment filters. They are pretty big and can be used in front of the pump. Big metal cannister type of thing, not that expensive. 9.85 @ 145mph
27th Feb, 2007 at 11:51:04pm
http://cgi.ebay.co.uk/FRAM-FUEL-FILTER-G58...VQQcmdZViewItem
28th Feb, 2007 at 05:48:31pm
thank guys |
28th Feb, 2007 at 07:36:11pm
Maybe its just me. But I would not out a filter with an 8mm OD hosetail in front of an efi pump that has a larger hosetail.
28th Feb, 2007 at 11:14:23pm
On 27th of Feb, 2007 at 10:58am mickeyturbo said:
ok so what filter is best for me if im using an spi tank? On 28th of Feb, 2007 at 07:36pm stevieturbo said:
Maybe its just me. But I would not out a filter with an 8mm OD hosetail in front of an efi pump that has a larger hosetail. That filter would be ideal after the pump though. I have said this before, how do you fit a pre filter to an intank pump? Not being funny by the way
1st Mar, 2007 at 06:52:45pm
Maybe its just me. But I would not out a filter with an 8mm OD hosetail in front of an efi pump that has a larger hosetail. That filter would be ideal after the pump though. I have said this before, how do you fit a pre filter to an intank pump? Not being funny by the way ![]() Most if not all in-tank pumps will have a bag/gauze filter already attached to them, or one that can be attached. 9.85 @ 145mph
1st Mar, 2007 at 11:17:33pm
Very true.
2nd Mar, 2007 at 07:34:07am
Well having had a brand new pump seize on me due to shite getting in it i run a pre-filter.
2nd Mar, 2007 at 05:34:04pm
Is that a filter or a strainer, very different things On 26th Oct, 2004 TurboDave16v said:
2nd Mar, 2007 at 05:42:23pm
On 2nd of Mar, 2007 at 07:34am iain said:
Well having had a brand new pump seize on me due to shite getting in it i run a pre-filter. Its got 10mm tails, is see through and rebuildable and was about £10 from demon thieves i think. All Facet's run a pre filter and they're used on some high output engines that i dont hear of having any problems due to it? ![]() Facet pumps pump a miniscule amount of fuel compared to an efi pump though, and many would be used in a dead end system, instead of a return style. I broke a pump once due to lack of pre-filter. I then added a steel bodied inline filter with 10mm hosetails between tank and pump. I had no end of trouble with it. I was surprised, as it was what I thought a reasonable size, at about 1.25" diamater and some 3" long. Which for most inline filters at the time seemed big. The pump made all sorts of noises, and under load, the car always had running problems, related to lack of fuel. eventually I re-worked the tank to accept a 12mm steel pipe, with a metal gauze on the end as a prefilter ( froma cavalier SRI pickup actually ) and dumped the 10mm inline filter. All problems were solved, and the pump was nice and quiet again. For reference, I currently use an Aeromotive fuel filter with a 100mic stainless element before my 2x044 pumps on the granada. That filter seems to work fine. I would have used 2, but my tank was made with only 1 outlet.....lack of forethought when I had the tank made. 9.85 @ 145mph
2nd Mar, 2007 at 09:14:32pm
minisprocket, that one i have bought from the link u posted... it will be ok to use on the spi tail from the pump? |
