Home > Help Needed / General Tech Chat > Normal T3
webba
Member #: 1495
Obviously besides the manifold, is there any difference between say a T3 off a cos/rs turbo and the normal metro t3?
Any special wastegate or actuator requirements?
Edited by webba on 27th Feb, 2007.
Basically the most important thing is different; the size of the compressor and turbine.
T3 is a generic model name refering, I assume, to the basic scroll and blade design along with the bearing housing etc.
Different AR ratios make it then suitable for varying situations/engine sizes.
Wil
webba
Member #: 1495
Thanks for the info mate
Cossie T3 uses a different style of turbine housing.
RST is the same, albeit with a larger A/R
Turbine shaft itself is what the T3 really refers to, as I think its the same shaft for all T3 units ( unless modified afterwards )
