Home > 998cc > cc
weewheels
Member #: 1508
n ireland killyleagh
does anyone know the cc of a standard 998 head i take it is mmore than a 12g940 head. cheers.
I'm stupid Ive A fiesta with most of the bits to make my megajolt thingy. Thick or what!!!! OHHHHH and ive got a metro for free !!!!! Metros have become rare over here!!!!!!!!!
http://s216.photobucket.com/albums/cc273/weewheels_2007/
Although Vizard doesn't state th e998 head specifically I think its 24.5cc
hario
Member #: 2885
""However, one thing you should appreciate is that the open chamber small bore heads have the largest combustion chamber of all heads at 28.3cc.""
vizard humself..
""On the other hand, a 12G940 casting starts off life at 21.4cc""
so pocketing a 998 and fitting a largebpre head means adding 6.9cc's..
*happy*
Edited by hario on 26th Jun, 2008.
Ben H
Member #: 184
Melton Mowbray, Pie Country
vizard humself..
*happy*
28.3cc might be a 12G295 head, but not a standard 998.
According to the above the pockets will be 28.3-21.4+6.9 = 13.8cc. That is a mighty big pocket!
http://www.twin-turbo.co.uk
hario
Member #: 2885
ring land volume is approx 2cc gasket volume another 2cc
small dish, dished pistons are 6cc i think?
Ben H
Member #: 184
Sorry I am being an arse, but what are you saying here?
hario
Member #: 2885
sorry i was just trying to out do you.. *tongue*
i was waiting on my pipette kit in the post so i can get some hardfacts down but theyre out of stock..
ring land volume is the capacity between the piston and the bore in the space between the top piston ring and the top of the piston crown..
gasket volume is part of the combustion chamber,
eg. 65mm bore with 1mm thick headgasket (copper) then
Ï€(3.14) x radius of bore(3.25cm) squared, times depth(0.01cm)
somethink somethink.. too wasted.
Edited by hario on 14th Jul, 2008.
Home > 998cc > cc
