Home > General Chat > Quickracks
t3gav
Member #: 229
Gavin@minispares.com
kent
Just wondering what peoples opinions are on these, don't want to fit one and be dissapointed and have to take it back out, cheers
I have one fitted. I like better over a standard one!
miniminor63
Member #: 672
The oversills police
Oslo, Norway
I am using one, I like it, and have gotten use to it, so when the first one where worn after 4000 km's of use I went and bought a new one.... In other words, they feel good but are lousy quality...at least the ones from minispares.
i looked into getting one, but its something like 2.2 turns lock to lock, compared to 2.7
i thought that half a turn isnt much and decided against it
miniminor63
Member #: 672
Oslo, Norway
you can definitely feel it, I had two minis for a while now, one with and one without, and I personally preferred the quick racked car.
mmm rack quality has gone downhill evidently,
i fitted a new recon one a year or so ago and it never felt right from the off.
Titam motorsport are/will be doing a rebuild kit that can be fitted without removing the rack!? with Keith Calver, looks promising.
Hmm thats strange, ive had mine ages and its been fine. I have had on 2 cars in fact!
you've had it ages... thats probably why its fine!!
on my mk1 i binned the original rack and put a new recon one on, the new one was worse!!
the quality of the recon racks sems to have got worse in the last 3 or so years.
miniminor63
Member #: 672
Oslo, Norway
yes, but the LHD quick racks as supposed to be NEW, not recon, but still the quality is crap...I have heard others over on the minimania board with similar problems.
shane
Member #: 1246
Lowestoft, Suffolk.
Ive had a quick rack on one of my cars for 3 years no problem with it, like the way it feels.
Shane.
My dads had a standard new genuine one before and that was very good quality, is it just the qr that are shit or all?
Jay#2
Member #: 648
Northern Ireland (ex AUS)
What's the average life of a rack? Like mines 28 years old and I was contemplating on getting a new one.
On 7th Nov, 2008 Nic said:
naeJ
m
JT
Member #: 637
Hertfordshire
is it worth it?
how long does it take you to put it on full lock when you need to anyway?? i never find a standerd one a proplem!
cheers
josh
My build thread..
http://www.titan.uk.net/products.php?secti...subsectionid=47
not cheap by any means! but allegedly good.
t3gav
Member #: 229
kent
I know the standard one is ok, but sometimes in the twisty stuff your arms are just a bit too crossed..
andeh
Member #: 97
Near Daventry, midlands
surely wear on racks is down to mileage not age? The one on my 62van is still perfect, but i couldnt tell you if its been replaced in the fist 15years of its life.
Jay#2
Member #: 648
Good point, mine must have done about 100k miles then. Can you tap it for a grease nipple or is that just silly?
naeJ
m
most have a removable plug, pull the bung out where the steering column would be on a LHD car and you should see it if it has one.
you can take that out and stuff a bit of ep90 in.
Jay#2
Member #: 648
Oh right I didn't know that. I thought they were all pretty well sealed. Might give that a go next time I'm under the car.
naeJ
m
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
Jay, not under the car, from inside!! On the passenger side bulkhead there is a grommet which covers a plastic allen bolt. remove that and you can top the rack up. The main reason for the plastic alen bolt to be there though is that once removed you can put a drill bit (1/4" I think) in to the rack to hold it central as you build up the steering assembly.
RogerM
Member #: 1217
My personal opinion on quick racks are;
track / competition car ..yes ... definately
road car .. no
My reasoning is that the steering on Mini is both direct and heavy as standard. Fitting a quick rack can actually make a road car more difficult to drive smoothly for the 99.9% of the time your not actually in need of it, especially when parking etc.
I'd not have a competition car without one though as I tend to set the back end up somewhat loose.
miniminor63
Member #: 672
Oslo, Norway
I agree with you to a degree there Rog! But it isnt really much worse to park with either.
I feel that also the use of an LSD diff will break racks, as it puts some force on the car when you are turning sharp.
RogerM
Member #: 1217
Again, a reason I won't use LSD's on a road car. That and the fact that on UK roads they tend to promote tramlining and the like due to the grooves the trucks create and the fact that damage to the surface has to get so bad people disappear down them before anything is done!
As for not being bad to park I know at least 1 person who couldn't even turn the wheel on my last car with a quickrack on (175/50/13's, 300mm steering wheel) .... she almost ripped the column out trying!!! As the driving tuition in this country is a joke and most people learn in modern cars with super light power steering people don't learn to spin the wheel whilst the car is moving.
Also as 99% of road users, around where I live at least, are inconsiderate cnuts you often find you get back to the car to find 2" infront and 2" behind!!!
JT
Member #: 637
Hertfordshire
a tow bar and a bullbar would soon solve that!!*evil* *happy*
would look a bit silly on a mini mind lol*happy*
My build thread..
indeed..
one good reason not to have arcch extentions... the you can just grab the rear arch and bump the back round.
