| Home > Help Needed / General Tech Chat > celly paint advise :-( maybe one for mr benross?? | |||||||
10th Mar, 2007 at 09:50:23pm
sorry about the long winded post
10th Mar, 2007 at 10:04:43pm
I know some one In Ellesmere Port that can do celly, I can ask, if you need help. I dont think he will charge much if hes willing to help, if you want help
Edited by Sprocket on 10th Mar, 2007. On 26th Oct, 2004 TurboDave16v said:
10th Mar, 2007 at 11:06:57pm
you may get better results if you flat what youv'e done back with 1000 wet and dry and giving one final coat a bit thinner mix and getting a complete wet coat, cpmplete wet coats are the key to success, it saves flatting back time, ultimatly if you apply numerous coats , and built up the layers, you can flat it all back with superfine 1500 untill you see a complete dul;l surface ,ie; no tiny pipos or traces of orange peel then its time to cut back with a good compound then a final polish,
Edited by fastcarl on 10th Mar, 2007. |
11th Mar, 2007 at 01:04:05pm
took both our advise been in the garage this morning and rubbed it down and recoated with 75/25 thinner/paint so as soon as it dries ill keep you informed as long as the bits you can see when its all back together are smooth then ill be happy. no longer a series, but still 1.3 turbo.
11th Mar, 2007 at 02:07:20pm
The absolute key here is to keep a "wet edge" at all times, this helps the finish immensely.
11th Mar, 2007 at 03:57:43pm
Now I remember why I use 2pack....
11th Mar, 2007 at 05:42:09pm
On 11th of Mar, 2007 at 02:07pm Tom Fenton said:
The absolute key here is to keep a "wet edge" at all times, this helps the finish immensely. And then with celly increase the thinners content for the last coat, then break out the flatting compound/superfine wet and dry. exactyly what tom says carl, thinners for last coat 70%
increase gun pressure to 45 to 50psi last coat
previouse coats 40psi
11th Mar, 2007 at 09:24:18pm
cheers people im sure ill get there. the insides now much better the bits that will be visible are good enough, smooth and shiney. i think the outside will be easier, theres to many nooks and crannies in the inside. hopefully be ready for painting the outside within the month.
![]() 1913 Posts Member #: 1392 Pointless Post Whore Liverpool, North west |
11th Mar, 2007 at 10:56:27pm
Just do what Mr bean did Carl and chuck a firework in a can of gloss and run outof your garage! Alot quicker and you MIGHT catch up to me!!!!LOL Back once again like a renegade master |
11th Mar, 2007 at 11:10:43pm
and dont forget your teddy... "Turbo's make torque, and torque makes fun"
