| Home > Help Needed / General Tech Chat > Plenum HEAT | |||||||
![]() 826 Posts Member #: 247 Post Whore Kent/Surrey Borders |
18th May, 2004 at 11:31:23am
Does anyone have any idea how hot the Plenum can get? TurboLessTosser |
18th May, 2004 at 11:39:26am
I would very much doubt it. Fair volume of air going through it plus its a long way from the turbo really. Tops id say would be 80ish. |
18th May, 2004 at 11:40:55am
Cool !!! ( no pun intended )
TurboLessTosser |
18th May, 2004 at 11:44:34am
Would of thought that would be fine. End of the day just see what happens but that side of the plenum shouldnt get anywhere near 100degrees.
166 Posts Member #: 221 Advanced Member |
18th May, 2004 at 12:02:35pm
I had mine welded as I had never heard of this liquid weld stuff, is it any good?
18th May, 2004 at 12:10:31pm
Ive had mine TIG'd aswell. Suppose if the pipe is a tight fit then it shouldnt be a problem as they will be most of the strength, the reason i didnt was because i wanted mine running at 45degrees to the slope of the plenum, i.e. horizontal to prevent things hitting the bonnet etc. Liquid weld wouldnt of done the job as the fit wasnt perfect of very tight, welding was the only option. |
18th May, 2004 at 12:30:26pm
The air in the plenum can get to about 130 degrees depending on the boost you run.....
AlexF |
18th May, 2004 at 01:53:50pm
I think I will just have to wait and see if it falls off !!!
TurboLessTosser |
18th May, 2004 at 02:34:03pm
with an intercooler I would hope so!
AlexF |
18th May, 2004 at 06:31:41pm
yes that right it will get hotter than 100. Best 1/4 mile 13.2 seconds @116 mph
19th May, 2004 at 11:36:56am
I would have said it would get hotter than 100 degress when you turn the engine off, only a few inches below the plenum your turbo sits which get into hundreds of degress Edited by Jimster on 22nd May, 2004. Team www.sheepspeed.com Racing
21st May, 2004 at 10:52:15pm
yes Jim i wouldn't want to be a Plenum chamber LOL! Best 1/4 mile 13.2 seconds @116 mph
