| Home > Help Needed / General Tech Chat > Master cylinders, which to use? | |||||||
2647 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
14th Mar, 2007 at 10:30:21pm
Have been out in the garage again this eve and weighing up which parts under the bonnet of my turbo minus build will pertrude above the bonnet line (as the minus is 3"less in height, and all the parts in the bay affectivly seem higher in reation to bonnet) and found that the master cylinder I was planning to use sits above the bonnet will sit over an inch and a half into the bonnet,
14th Mar, 2007 at 10:36:37pm
Use AP Racing ones, I have these on my 150 banana MiniSprint. Theyre well upto the job.
I seriously doubt it! |
14th Mar, 2007 at 10:46:27pm
shane, i have single tin can
14th Mar, 2007 at 10:52:44pm
I'm not sure if I saw it in the Merlin or Rally Deisgn cats but I know I recntly saw a dual / tandem master cylinder for remote resoviors.
14th Mar, 2007 at 11:07:14pm
Paul, who stocks the AP items, and at what cost?
14th Mar, 2007 at 11:18:03pm
Out of interest does anyone know when dual / tandem set-ups become a legal requirement? Isambard Kingdom Brunel said:
14th Mar, 2007 at 11:19:36pm
Thats a good question, my build is a '68 will this be a problem? I doubt it will as im sure i've seen newer cars running single line.
15th Mar, 2007 at 12:03:33am
shane i have just looked my memory is crap
15th Mar, 2007 at 12:42:54am
Thanks benross, been sat here thinking some, and have realised i have already ran the pipework round the front subby for twin pipe set up, and am reluctant to change it, so am now thinking, as another option using the servo master cylinder set up from the (I think), 1990 on model (master cylinder into the bay rather than on top of cross member)
15th Mar, 2007 at 12:58:31am
demon tweeks sell those ap cylinders,
15th Mar, 2007 at 12:59:58am
Cheers Nic, is that single or twin line?
15th Mar, 2007 at 01:03:28am
errrr single...i think.../???? |
15th Mar, 2007 at 07:09:14am
On 14th of Mar, 2007 at 11:07pm shaneyboy said:
Paul, who stocks the AP items, and at what cost? Roger, like the idea of duel better, not going to have the low car and brake line issue as they are all being ran internally. Benross, is the can you have the 3"tall "s"/ GT item? also do have a link to the bias valve (please) Thanks gents, appreciate it Shane. I am refering to the flexible hoses that run from the shell to the rear radius arms ..... often found rubbing on the body on low cars, sometimes they can get trapped and cut if they aren't fitted 100%. Every day is a school day ...........
15th Mar, 2007 at 07:10:41am
On 14th of Mar, 2007 at 11:18pm British Open Classic said:
Out of interest does anyone know when dual / tandem set-ups become a legal requirement? I would have to go and look it up to be 100% sure but it was either '80 or '81. Candice's '78 defo came with a single line .... now in the bin. Every day is a school day ...........
15th Mar, 2007 at 07:13:44am
On 15th of Mar, 2007 at 12:42am shaneyboy said:
Thanks benross, been sat here thinking some, and have realised i have already ran the pipework round the front subby for twin pipe set up, and am reluctant to change it, so am now thinking, as another option using the servo master cylinder set up from the (I think), 1990 on model (master cylinder into the bay rather than on top of cross member) Do you guys think it is possible to use this set up, but less the servo (ie master cylinder to the linkage from the pedal box to which the servo normally mounts). Space is of a huge premium in the bay of this build, and would also rather not to have a servo. This is going to take some further head sratchin! Thanks Shane. The short answer is not really, the pedal ratio is quite different and the whole frame is a bit overly bulky. Why not just fit a late front/rear split master and the valve that goes with it (4 pipe job on the bulkhead .... there to shut of a line that goes very low pressure)?????? Easy and very safe install and not going to intrude into the engine bay any more than a single line ........ I personally do not understand why anybody would run a single line system. Every day is a school day ...........
16th Mar, 2007 at 12:53:23am
Edited by shane on 16th Mar, 2007. |
16th Mar, 2007 at 01:28:20am
i'm also running a single line setup the same as benross, it splits on the bulkhead at a T piece in pretty much the same place as the bias valve on a tandem setup so your front and rear pipes should still be useable. On 20th Oct, 2015 Tom Fenton said:
16th Mar, 2007 at 01:39:04am
What about the front, at the mo, the line comes from the bias valve, to the top of the flesi (drivers side) runs round the front of the subby, to the the pas side flexi, if I run a single line system will the front subby be piped differntly? does the "t" for the rear brakes take off before or after the "t" for the front, is it like this? http://www.miniminus.co.uk/pictures/29%20-...ne%20-%2003.jpg
16th Mar, 2007 at 07:27:25am
Down side of single line is that loose one part of the system you use it all ..... resulting in a near certain trip to hedge!!! Edited by RogerM on 16th Mar, 2007. Every day is a school day ...........
16th Mar, 2007 at 05:48:25pm
LOL @ Roger! |
538 Posts Member #: 119 Post Whore Staffordshire or Northamptonshire |
16th Mar, 2007 at 08:22:39pm
These guys are good AP dealers. They know their stuff and can get hold of anything from AP quickly if they aint got it.
16th Mar, 2007 at 09:53:58pm
On 15th of Mar, 2007 at 07:10am RogerM said:
I would have to go and look it up to be 100% sure but it was either '80 or '81. Candice's '78 defo came with a single line .... now in the bin. Mine's a '79 and came with a split system. Don't know if that helps. On 7th Nov, 2008 Nic said:
17th Mar, 2007 at 10:07:58am
Thanks for that Richard will give them a bell next week. I think Im going to struggle to fit a twin line master cylinder (without using the off the baulkhead bulky I saw servo used on the later cars) due to my height restriction, I had a look at the AP twin line servo that my boss is running on his caterham, its a little longer than the item I was planning to fit.
18th Mar, 2007 at 03:11:17pm
AP do a few different styles of cylinder. You can use remote resovoir units to help keep your height down, but the res must be above level of the master cylinder.
18th Mar, 2007 at 06:23:59pm
cheers again Richard if the ap unit is only say an inch less in height im gonna struggle then to get the resevoir higher, I think A realistic solution to my problem is either use, single line system or the later twin line servo assisted item (which I loath the look of, very unpleasing to the eye!)
