Home > Wanted > Wanted Brace Bars for Saloon
Doodles_Mcpooh
Member #: 1252
Cornwall
After a set of brace bars if anyone has some for sale.
paneermeel
Member #: 1404
The Netherlands
make youre own...
a piece off steel, welled some tabs on them and bingo!!!!
saves you some money you can spend somewhere else *wink*
there is nothing wrong with a A-series that a turbo can't fix.
www.turbomini.nl
for the sake of £30, just buy new.
http://www.minispares.com/Product.aspx?pid=36383
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
If you had no material around you'd be looking at about £12 - £15 for the 1" sqr box section in a reasonable thickness and you'd have to spend another £10 or so on the material for the end tabs if you have to buy a length.
To be honest even with the material around I'd buy as the time to mark out etc if you've never made them before will be more than you'd have to spend at work to pay for a set.....
I'll probably make them for my car but then again I'm a tart and like everything to be a little unique in some way...
If you ask around a few fabricators you can get normally pick up the steel for beer money.
I'll probably be making a pair shortly, as I enjoy making things, especially if the welder is involved.
Out of interest are the off the shelf brace bars solid mounted or are there bushes in there (not sure how you'd fit bushes mind).
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Problably get off cuts for nothing....beer is good for bartering.......
