Home > General Chat > Good Samaritan
MiniTurboBadBoy
Member #: 483
Merthyr Tydfil
Hi
Could any kind experienced mechanics in the cardiff (Merthyr Tydfil) area come and fit my hi los and knuckle joints? I got forty quid for beer money and a favour!
Cheers Chris would well appreciate it
MiniTurboBadBoy
Member #: 483
Merthyr Tydfil
Please lol
Jay#2
Member #: 648
Northern Ireland (ex AUS)
There will be someone along don't worry. If you can be bothered forking out the £35 for a cone compressor it really is an easy job. I did it and that was partly without the use of a compressor. The annoying bit for me was getting the pin out of the top arm, on the drivers side theres a brake union in the way but if I can do it so can you. Getting them in is easy as you can shorten the hilo to get it in. Getting the cups out of the top arm was OK for me but can give trouble, nothing a blow torch won't fix.
On 7th Nov, 2008 Nic said:
naeJ
m
MiniTurboBadBoy
Member #: 483
Merthyr Tydfil
Im just affraid I might start something I cant finish and then the car will be stuck in my garage I was quoted £100 from a garage near me that are suppose to be good with minis!
do you a deal
you buy the cone compressor and have a go yourself, if you cant do it ill come over foc and do it for you
Jay#2
Member #: 648
There you go, try it yourself. If you suceed you feel good about yourself and it only cost you £35. If you get stuck then there's help at hand. Can't loose.
naeJ
m
MiniTurboBadBoy
Member #: 483
Merthyr Tydfil
cheers Wolfie theres one on ebay.
So you dont need the tool to change the back just the front?
thats right *smiley*
pry bars great for popping rears out
I would help mate, but I'm snowed under, got two miglias and a class 7 autograss car to re-wire
Mini_Andy
Member #: 432
however if you dont have one of them either then a big screwdriver and hammer usually does the trick lol
i would offer to lend you my compressor, but i cant find it, will keep looking though :)
MiniTurboBadBoy
Member #: 483
Merthyr Tydfil
Cheers guys will keep you updated
Jay#2
Member #: 648
I would suggest maybe getting liberal with the WD40 the night before help arives (or before you do it yourself). I didn't need too, the rear trumpets and cones came out OK but hey it won't hurt!
naeJ
m
