| Home > Show Us Yours! > WANTED, pics of supercharger installs | |||||||
![]() 902 Posts Member #: 111 Post Whore Loughborough |
26th Mar, 2007 at 04:58:31pm
As the title says really... if any one has a Vmax kit i would very much like to see how the kit has gone in and what you thought to it, Also if any one has got a jonspeed set up and if they have had problem with it.
26th Mar, 2007 at 06:10:47pm
Alex .... get along to the Mini Spares Bonnaza at Stoneliegh on the 8th April .... Jonspeed will be there I'm sure as they are only just up the road.
26th Mar, 2007 at 06:16:26pm
http://www.vmaxscart.co.uk/
26th Mar, 2007 at 09:45:58pm
your more than likly right that i could build a supercharger install my self. only really tricky bit is the inlet manifold and possibly the bottom pully mods. But Vmax and jonspeed talk about mods they do to the charger but i don't know what these mods are. the BMW charger as far as i know isn't designed to put fuel though but both people put the carb before the charger and there for fuel is going though.
26th Mar, 2007 at 09:47:31pm
this would be a good manifold to start on but bit pricey.
194 Posts Member #: 1296 Advanced Member Milford Haven Pembrokeshire |
30th Mar, 2007 at 07:57:04pm
Here's some of mine |
30th Mar, 2007 at 08:02:51pm
Added attachements but they don't seem to have appeared! |
30th Mar, 2007 at 10:01:04pm
ok, lets try this way. Heres a link to my pics on here!
30th Mar, 2007 at 10:07:57pm
Here you go,
30th Mar, 2007 at 10:12:04pm
cool car by the way, and an interesting solution to the bottom pulley. On 28th Aug, 2011 Kean said:
30th Mar, 2007 at 10:36:44pm
The drive belt is an optibelt omega m8 toothed timing belt (they come in loads of sizes, this ones 1120) and the pulleys are readily avaliable if you search google for 'm8 pulleys' |
30th Mar, 2007 at 10:49:36pm
ok... i NEED more info on how you put all that together and done the bottom pulley. If you got a second please Add me on you MSN, emails is alex.heap@hotmail.com same goes for any one on the site. cheers alex. |
34 Posts Member #: 1634 Member |
4th Apr, 2007 at 11:59:08pm
hi guys - new member from new zealand, although ive been reading this site for a long time theres alot of good info on here,
5th Apr, 2007 at 12:11:23am
That should be a good set up... isnt that blower a screw type? On 28th Aug, 2011 Kean said:
5th Apr, 2007 at 03:34:35am
their a routes type (spelling??) it can handle up to 14 psi i think before it destroys the coating on the rotors, around about 8 with the standard pully, another good thing is it has a magnetic clutch so i can turn it on and off (mad max style) |
44 Posts Member #: 1645 Member Adelaide Australia. |
12th Apr, 2007 at 01:32:18pm
I got the same setup. Yes it is a rootes type.
Supercharged 1964 Morris 850 - Now 1330cc with 7psi.
12th Apr, 2007 at 01:33:49pm
PS. The toyota charger is not designed to have fuel put through it, but the bloke (good bloke indeed) who makes the kits for that setup here in Adelaide puts water and fuel thru his at 12 psi so yeah no problems! Supercharged 1964 Morris 850 - Now 1330cc with 7psi.
52 Posts Member #: 1655 Advanced Member Norway |
12th Apr, 2007 at 10:26:46pm
Hi, and greetings from Norway!
![]() 162 Posts Member #: 1252 Advanced Member Cornwall |
12th Apr, 2007 at 10:36:33pm
Has anyone managed to mount a blower in front of the engine or is there not enough room? could you do it with one of those extended front jobbies? |
13th Apr, 2007 at 01:36:01am
A guy in Australia has a front mounted blower (above alternator) on a Moke, was in a Clubman front before that, won't fit a roundy though.
13th Apr, 2007 at 09:02:41am
I've seen one done like that in a mini mag or world afew mounths ago... had to cut some of the front out to get the pipes in. I think the carb was after the charger on that... |
13th Apr, 2007 at 08:59:09pm
I'm in the process of converting mine to front mounted! And it will fit under a round nose with no extensions.
