| Home > Technical Chat > Clutch confusion | |||||||
27th Mar, 2007 at 01:06:50pm
Ok if friction is dimensionless then increasing the area of the clutch wont increase the torque capacity right? I'm a bit confused as to why twin plate clutches etc exist then? Prob me being stupid but any info appreciated, cheers. |
27th Mar, 2007 at 01:29:21pm
The coefficient of friction is dimensionless, but in order to calculate a torque capacity you need to take into account the area the friction is acting upon, and the force normal to this area, in the case of a clutch the clamping load. These both have dimensions hence why increasing area changes the torque capacity.
27th Mar, 2007 at 01:32:48pm
...and hence why increasing the number of friction 'couples' increases the overal system torque capacity. On 17th Nov, 2014 Tom Fenton said:
27th Mar, 2007 at 02:08:06pm
Ah i see, i was confused in that i didnt see how area affected the torque capacity even though its in the formula, cheers :) |
27th Mar, 2007 at 02:14:57pm
Nope confused again, just read this from one of TD's posts: "It's nothing to do with area at all - friction is dimensionless (has no units). Hence you could take an organic plate and chop 90% of the material away - and it'll still hold the same torque." ?? |
27th Mar, 2007 at 02:35:40pm
Ok,
Edited by turbodave16v on 27th Mar, 2007. On 17th Nov, 2014 Tom Fenton said:
27th Mar, 2007 at 04:29:11pm
I didn't understand any of that at the start of the thread...Lol...all makes sense now.
27th Mar, 2007 at 05:40:16pm
Ok if increasing the area of the board doesnt have any effect on the force needed to move it then i still dont see how increasing the surface area of a clutch will increase its torque capacity. What am i missing here this is driving me crazy :- |
27th Mar, 2007 at 05:57:56pm
It's not the area as much as the acting radius IIRC. You don't often see people increasing the are towards the centre .... Every day is a school day ...........
27th Mar, 2007 at 06:02:46pm
Ah i think i get it now, if you were to add extra area to the clutch plate it would make no difference at all to the torque capacity as the pressure would just decrease, however adding another plate will increase the area 100% for the same given pressure. I hope thats right? |
27th Mar, 2007 at 06:52:34pm
I think you have it...
27th Mar, 2007 at 08:33:18pm
Is it radius of gyration or something similar?
27th Mar, 2007 at 10:02:17pm
Yes Tom :) |
27th Mar, 2007 at 11:53:45pm
Tom .... you sure that isn't hip movement ...... maybe not Every day is a school day ...........
28th Mar, 2007 at 01:11:21am
On 27th of Mar, 2007 at 06:52pm TurboDave said:
I think you have it... Easiest analogy is a paddle clutch - say the ones with six pads on each side (12 total). You could remove three off each side, and the torque capacity will be unchanged. Inertia will be less of course (positive) but it'll wear faster (negative). You have three options with regard to uprating clutches: 1) increase clamping force, 2) Increase mean radius (it has a term I don't recall right now) and 3) Increase number of friction couples (firction surfaces). I was under the belief, that 3 paddles would grip better than 6 paddles, as forces acting upon them were greater. This doesnt make sense to me, as there is also less friction area. Clutches can be simple.....yet pretty awkward. 9.85 @ 145mph
28th Mar, 2007 at 12:28:02pm
Stevie you answered your own question lol, there is less friction area but the pressure is proportionally greater so the torque capacity remains unchanged. |
