Home > Technical Chat > IHI turbo help
chappers
Member #: 1428
Cleveleys
Hi need some help. *oh well* Got a IHI turbo for free today, it's apparently off a diahatsu charade turbo.
The only prob is there is no actuator, will i be able to fit any aftermarket actuator to it?
also there must be 4 or 5 tapped holes in the body of the turbo, i know 2 will be for oil feed and return, but are the others for some water cooling?
what pipes should i use for the oil feed and return, and where do i take a feed from the block?
sorry there are so many questions
Chris
998 turbo in progress.... DONE..........KNACKERED LOL
Yes
Probably water cooling, yes.
You'll need a braided hose making up with banjo connectors. these are available for T3s and T2s off the shelf from places like Avonbar. What I have done for my new turbo is modify a T3 hose by buying the correct banjo connector for the turbo and hose size. And most people take the oil feed from the oil pressure sender hole.
chappers
Member #: 1428
Cleveleys
Thanks Wil,
will this actuator be suitable for the IHI turbo?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...22023&rd=1&rd=1
I don't suppose you have a spare metro turbo manifold kicking around?
cheers
Chris
