| Home > Help Needed / General Tech Chat > coil/dizzy wiring | |||||||
298 Posts Member #: 1357 Senior Member telford,shropshire |
4th Apr, 2007 at 09:47:23pm
hey chaps, got me engine in now and pretty much all wiried up.
'always keep a spare shot for a stray bird' |
4th Apr, 2007 at 09:52:59pm
There should be two wires from dizzy to coil, white/black from module to negative side of coil, white/yellow from module to pos side of coil, then a switched 12v feed to coil from fuse box as you mention. If you have all those three you will have enough for the engine to run.
4th Apr, 2007 at 09:57:30pm
thanks tom, ive only got one wire from the modual and its white??
4th Apr, 2007 at 10:00:09pm
Jamie, that wire might not be an original, but i think the white on the mini is live.
Edited by MarkGTT on 4th Apr, 2007. |
4th Apr, 2007 at 10:04:49pm
thanks mark, i fin wrk at 11.30 2mora so will have another crack at it then. 'always keep a spare shot for a stray bird' |
5th Apr, 2007 at 09:17:45am
On 4th of Apr, 2007 at 09:52pm Tom Fenton said:
white/yellow from module to pos side of coil, then a switched 12v feed to coil from fuse box Switched is the key work here, do not be tempted to connect it up to a perminent live as you will burn the coil out in no time. Also you will need to run a wire (traditionally white & black) from the - side of the coil direct to the rev counter. Isambard Kingdom Brunel said:
![]() 232 Posts Member #: 1197 Senior Member Dublin Ireland |
5th Apr, 2007 at 12:40:10pm
I found this diagram useful when I was wiring up one of mine many moons ago!
100 Posts Member #: 745 Advanced Member Northampton |
6th Apr, 2007 at 12:59:36am
and i can make you up a lead should you need one...
6th Apr, 2007 at 07:39:26pm
cheers guys for all the help, wired her up 2day and got her running, well happy.
![]() 384 Posts Member #: 4215 Senior Member |
15th Jan, 2010 at 11:54:59pm
hi guys
17th Jan, 2010 at 02:44:42pm
anyone?? |
17th Jan, 2010 at 02:47:57pm
What colour is it ???
![]() 83 Posts Member #: 7115 Advanced Member essex |
17th Jan, 2010 at 09:23:33pm
Leave it unplugged |
20th Jan, 2010 at 03:37:00am
thanks guys |
