Home > General Chat > Where can i get my turbo rebuilt with a 360 thrust
ROB1N
Member #: 664
South Wales (chepstow)
Where can i get my turbo rebuilt with a 360 thrust cheers
Many places, TurboTechnics being highly recommended. *smiley*
AET Turbos do a superb job too.
Minimad69
Member #: 1311
Yeovil, Somerset
or you could do it yourself
yes TurboTechnics seems to be very good
but is it really needed?
richminiturbo.
Member #: 719
Horndean - Near Portsmouth
What does it do? What are the benefits? What is changed?
Minimad69
Member #: 1311
Yeovil, Somerset
the only thing changed is the thrust bearing. replaces the old 270 degree one with a new 360 degree one
ROB1N
Member #: 664
Basically I have a Morspeed turbo challenge engine and a turbo booster head so the turbo needs a recon ,one theres no point in doing half a job and i should be running 15psi.
Somebody said do it yourself but dont you need to balance the turbo.
Yes, they must be balanced.
But I assume they mean to re-assemble the turbine and compressor wheels in the exact same alignment as they came apart, in which case, balance should remain as it was.
Minimad69
Member #: 1311
Yeovil, Somerset
The turbine and compressor wheels need balancing once they have been apart (unless you re-assemble the turbines and turbine nut back on the shaft in exactly the same position), theres a few places you can build the turbo yourself and send it off to get it ballanced, costs about £50 iirc
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
MiniMad69 .... any contacts for doing that as nobody I spoke to wanted to know about balancing a unit they didn't build.
