Home > Help Needed / General Tech Chat > RS Turbo Intercooler Info
Anyone know off-hand what the OD of the inlet/outlet is on an S2 RS intercooler.
Wil
50mm exactly. :)
Thank you
Its 60mm, I had to use 58mm to 52 reducers, im currently using the same reducers on my cossie 2wd cooler now aswell.
I have a cossie intercooler and have seen some RS hoses on Ebay that I just wanted to know whether they wold fit or not.
I'm doing this install on the cheap.
The reducers I used were a good fit on the R5 cooler but really tight on the cossie one. I recon the cossie ones must be about 62mm (ish).
I recon they should stretch over with a bit of washing up liquid. *wink*
Edited by matty on 25th Apr, 2007.
Matty/Wil
Wil's on about the Escort RS turbo and matty the Renault 5 turbo right?
Just so you dont get your wires crossed.
hence TD's 50mm applies to the Escort and matty's 58 type size applies to the Renault 5.
Didnt want anybody buying the wrong thing *smiley*
That sound right gents?
Nick
Member #: 154
Midlands
yup the scrot IC is 50mm.
wil, i got hold of a set of std cossie hoses when i did mine originally on the cheap. they work quite well if you chop em up, pretty sure they reduce down to 50mm aswell making life easier.
yes Iain, I worked that out, was abit confusing though.
Cheers Nick, that's the kind of info I wanted. I think there might be a cossie set on ebay atm.
LOl...Note to ones self.....book appointment at optitions. *laughing*
Sorry Wil....been one of them weeks!!
