| Home > Help Needed / General Tech Chat > Timing chain noise | |||||||
28th Apr, 2007 at 02:45:10pm
My timing chain is getting very noisy.
In the 13's at last!.. Just |
28th Apr, 2007 at 02:48:22pm
Change it. |
28th Apr, 2007 at 02:54:23pm
Any reccomendations on where to get a good one from? In the 13's at last!.. Just |
28th Apr, 2007 at 03:04:23pm
dsn classics mate www.dsnclassics.co.uk always looking for them bigger bunches of bannanas |
28th Apr, 2007 at 03:18:39pm
Is the turbo single or duplex as standard? In the 13's at last!.. Just |
28th Apr, 2007 at 03:33:43pm
Single as standard, duplex is a worthwhile and easy upgrade though, remember to countersink the two bolts near the crankshaft and use 1/4" UNF countersunk screws to clear the crank gear, apart from this its a direct swap, also whilst you are at it replace the rubber tensioner buffer pad with a new one, only a few pounds for the part.
28th Apr, 2007 at 03:47:34pm
Thanks Tom,
28th Apr, 2007 at 04:49:51pm
do as tom says, its only a case of an hour or two to drop the engine and make it very easy. otherwise i reckon it should be possible with the engine in and an angle drill but i wouldnt like doing it. |
30th Apr, 2007 at 10:03:56am
It is possible with engine in, once the old chain and cover etc is off, it is only a couple more bolts to remove the steel front plate, you can then countersink it on the bench before refitting it with a new gasket.
