| Home > Help Needed / General Tech Chat > Mk1 tunnel profile and rod change gear selector linkages. | |||||||
2647 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
7th May, 2007 at 04:27:15pm
My minus has the mk1 style tunel for remote gear selector, when I purchased the car it was running an auto box, is it possible to cut a hole (as per mk3 tunel) and use a rod change assy or am i best cutting it out and taking a mould from a mk3 tunel and moulding my own to bond in?
7th May, 2007 at 04:36:30pm
You can get the rod change in, but you'll need to cut the hole out bigger so the alloy rod change housing can poke through, and making up a new mount as the old one bolts to the top of the later square tunnel, also fixing a gear lever gaiter down could be fun!....
7th May, 2007 at 04:58:06pm
I had thought of an early box but that was after having turbo hogster rebuild my 4 syncro rod change box.
7th May, 2007 at 06:47:31pm
You can do it, make a semi circle bracket following the tunnel radius that mounts to the alloy rod selector in the standard position with two cotton reels. A mk1 gaitor will fit no problem. I had this arrangement on my Sprint until recently with great success.
I seriously doubt it! |
7th May, 2007 at 06:53:37pm
is the tunel shallower than on a mk3 (later squarer) tunel, will the alloy rod selector then sit lower?
7th May, 2007 at 06:55:08pm
Yes but only 1/4 inch, nothing to worry about
8th May, 2007 at 07:48:53am
I think I've seen that bracket for sale somewhere. Possibly on Minimania. On 13th Jul, 2012 Ben H said:
8th May, 2007 at 09:51:02am
sure minispares sell that bracket as well V
8th May, 2007 at 01:15:45pm
i had a january 1960 mini and fitted the rod change to it. just drilled the holes for the cotton reals and bolted it in place |
8th May, 2007 at 07:20:57pm
If there is a bracket on the market it would save me hours of arsing about with little gain!!! Would make my life so much easier! thanks guys, will give minimania a try!!
9th May, 2007 at 07:41:27am
i can find it but try ringing Rich at minispares north. he's good for stuff like that |
9th May, 2007 at 10:37:32pm
Thanks Iain, will do!!
34 Posts Member #: 1634 Member |
10th May, 2007 at 04:13:01am
i made my own bracket out of the metro one i had in the shed and 2 cotton reel shaped mounts , sits in there quite nice and not too low - my exhaust will scrape before it does |
