Home > Help Needed / General Tech Chat > (verto clutch) Would it be ok ?
Mad_Turbo_Uk
Member #: 1690
My car is a std metro turbo.
Ill be running boost from 4 up to 10 psi, I wont be going over 10.
I know it's said that going over 10 psi means your have to change To a pre verto. but would it be ok to keep the the verto and just Ugrade the clutch ?
Cheers.
If you have a genuine 'turbo' cover, and use the AP organic race/rally friction disc, you will probably be ok.
If you had an uprated head, modified turbo, etc, then you would be at - and probably over - the capability of the Verto.
Hope that clears it up :)
