| Home > General Chat > why mini coilovers? | |||||||
164 Posts Member #: 1271 Advanced Member Berkshire |
9th May, 2007 at 04:02:12pm
probably a stupid question but cant you use coilovers from a different car? surely theres something out there that uses the same size ones, or similar?
9th May, 2007 at 04:03:53pm
Surely ones from a different car using 1.9" I/D springs with rose joint ends are just as expensive as the mini ones???
9th May, 2007 at 04:29:25pm
yea brand new, but what about if a car was to be scrapped that had em the same size? |
9th May, 2007 at 04:31:10pm
As long as the open/closed length of the dampers was something similar then should be OK although damping rates may not be as good as they could be for something light as a mini.
9th May, 2007 at 04:40:30pm
ok
82 Posts Member #: 939 Advanced Member |
9th May, 2007 at 05:07:21pm
you'd be very lucky to find a car with coilovers in a scrappy. let alone ones that would be any good for a mini
9th May, 2007 at 07:17:57pm
my mate is selling some pretty cheap, are they worth fitting? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
9th May, 2007 at 07:28:46pm
I can't see an advantage running them over a correctly sprung rubber car. For ultimate weight saving they are needed to run a beam axel, but rubber springs are great (just make sure you replace old ones) http://www.twin-turbo.co.uk
27th May, 2007 at 09:52:37pm
I prefer coil overs because I have a set of spring rates that I always use that combined with the rest of the geometry I use gives a super pointy car with just about zero understeer and a superb balance. Something that I have never got with rubber doughnuts.
