Home > Beginners Tech > Couple of newbie questions
Brocko
Member #: 1710
(and i have done a search, but couldnt really find anything to answer my questions)
After seeing the mirage manifolds, i am very tempted by this conversion, as i dont want to cut into the bulkhead.
Im thinking of going for a 1293 block (as i already have one) with a head i already have (unknown chamber size, but it has 38mm inlet & 31mm exhaust valves)
Question 1 - would that head be ok with the big valves?
Question 2 - Where would be the best place to get dished pistons for a 1293 + how much would they be?
Question 3 - Cam choice, i presume something "sensible" like an sw5 would be the best bet for a sensible turboed mini, if not what would?
Question 4 - Fuel tank, im under the impression i have to have a return line for the fuel. where can i get that done/how much?
Question 5 - Does the T2 just bolt straight on without any modifications?
Question 6 - will a turbo be fine running on a normal dizzy?
Question 7 - Will i need a dump valve/blow off valve & if so, where abouts would it be plumbed in?
There are a few more questions i have, but thats about it really for the time being.
Sorry for the long post!
Brocko
edit - TD. I removed Q7 out of yout first post and popped it in thias one before deleting it. :)
Edited by turbodave16v on 9th May, 2007.
Q1 = No. It will most likely crack.
Q2 = MED/Morspeed/Avonbar/Minits. Ring and ask.
Q3 = Normally aspirated cams such as SW5 not ideal for a turbo engine. Do some reading up on cam profiles on this site and you will find one comes on top every single time.
Q4 = Yes you need a return. Search for "MPI tank" as a simple way of achieving it.
Q5 = No. Do a search all the info is on this site if you look for it.
Q6 = Turbo dizzy is better, MegaJolt or other mapped ignition is much much better.
Brocko
Member #: 1710
i also appeared to have posted this twice, not sure how that happened!
Nic posted a good guide on the mirage manifolds. If you search for 'mirage guide' you might find it. :)
chinlesswonder
Member #: 1192
In the garage......again!!
Is this the same brocko who has a sh%^piecer%^ing t-shirt?. :)
If so, nice to see you here.
keith
133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
Shakespear RWYB 14.995 91.83mph
Brocko
Member #: 1710
Yes keith, its the same brocko from finity :)
hows your project coming along, it seemed nice when me and neil popped round the other week to grab that towrope! *happy*
