Home > General Chat > Has anyone checked.....
that they can get full throttle?
I noticed a while back(about a year ago lol) that when my foot was right down the butterfly wasn't fully open and I wasn't getting full throttle.
To sort the problem I just took the pedal off and twisted it a little so it sits a bit higher than the rest.
I only remembered I did this mod last weekend on the way to Newquay when my leg started aching.. *laughing*
i found my first mini noticable quicker when i took out the huge rubber floor mat (meant for a volvo) the previous owner had put in
I may stand a chance at Avon after all....could go round sticking bump stops on the under side everyones accelerator pedals. *laughing*
In my other mini a friend pointed out to me that if slid the mat back I gained another half inch of throttle.
andeh
Member #: 97
Near Daventry, midlands
You should be getting full throttle and sometimes it does require a bit of work to get. Although it does have to be said that its not as important as on Naturally Aspirated engines and even then only if they are close to the limit of the carb i would have thought.
It's the first thing I check after reconnecting a throttle cable. But quite commonly missed. All good RR operators check it at some point.
Dam, I'm a clever bastard!
chunk
Member #: 1719
swindon wiltshire
cut the carpet out arround the throttle pedal
good result guaranteed
Cutting carpet??, twisting pedals??
surely adjusting your throttle cable is easier?
I didn't have enough travel in my pedal, if I adjusted the cable my idle speed was way too high. *wink*
