| Home > General Chat > VR sensor position discusion MJLJ | |||||||
![]() 3184 Posts Member #: 628 Post Whore a LIL fishing village on the coast - Newcastle Upon Tyne |
14th May, 2007 at 05:57:22pm
ok i know technically this should probably be in the help needed section but as it is more of a general query i stuck it here.
On 17th Aug, 2009 Jay#2 said:
I doubt I'll be dipping into the 13's like you did though! |
14th May, 2007 at 06:08:42pm
I believe it has to be positioned at 9 o,clock looking at the front pulley.
14th May, 2007 at 06:18:07pm
The sensor needs to be 90 degrees before the missing tooth on the wheel, which is usually at TDC or 12 oclock, hence the normal sensor position being at 9 oclock.
14th May, 2007 at 06:45:51pm
Yeh, I was being a bit thick above.
14th May, 2007 at 07:10:05pm
You can indeed theoretically fit it where you want so long as the relationship between the missing tooth, TDC, and sensor is correct. However in practise you are limited by physical things, the water pump and fan belt for example. It makes it easy positioning it at 9 o clock looking at the pulley along the crank axis as you have the bottom face of the block to use as a reference.
14th May, 2007 at 08:17:57pm
Ahhh righto, reckon i will be ordering a sensor bracket in due course
![]() 171 Posts Member #: 621 Advanced Member nsw austalia |
15th May, 2007 at 07:59:38am
mine is place at around 7 o clock , as it doesent matter where it is as long as it is 90* anticlockwise from the missing tooth at TDC
1152cc turboed mini clubman, most powerful 1.1L a-series?
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
14th Mar, 2008 at 11:44:01am
bollocks!!!
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
14th Mar, 2008 at 01:54:38pm
You can't re-programme the EDIS module and thats the problem! AlexF |
