Home > Help Needed / General Tech Chat > Dodgy Crankshaft
webba
Member #: 1495
When I got my donor engine, I thought the crankshaft would be f*cked, but I was just after some opinions on the taper end. The rest of the crankshaft is fine and journals just need a regrind.
Im just not sure about the taper, theres light surface rust due to the clutch housing being removed.
Just seems a shame to waste a crankshaft
Looks more than light surface rust TBH, but clean it up with emery and see if you can get it back to a decent surface. If not a machine shop will be able to take a few thou off the taper to reclaim it.
I'd worry more about the primary gear journals.
That pitting looks pretty deep to me.
webba
Member #: 1495
aye true, reckon itll do as a exchange item?
This looks like a job for DANGEROUS!
andeh
Member #: 97
Near Daventry, midlands
aye it does indeed although surely worth finding a better crank?
Why do I have have an image of Dangerous in a cape and batman music playing in my head?
webba
Member #: 1495
lol, well i wasnt planning on using it at first anyway. Reground cranks from minisport seem cheap enough. Just want to make sure they take mine as a exchange item
MrTurbo
Member #: 814
Utrecht, The Netherlands
Clean it up really well before offering it as an exchange item.. specially the primary gear journal, looks unusable to me.
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
I'll have one similar soon for Dangerous to practice on ..... worth a try!
Brian if your reading this I will pick up the box, promise!!!
Dangerous
Member #: 417
Yes read it,working nights till at least August so no problems here !
