| Home > General Chat > Any one near completion with a mirrage build? | |||||||
2647 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
14th May, 2007 at 11:26:39pm
I am looking for a guinne pig! I have made an oil return pipe for the T2, and uses the silicone hose tht is standard fitment on the T3.
15th May, 2007 at 08:01:43am
I think there was talk a while ago about using brazed copper pipe for the oil return, and I think the consensus was that there could be issues with brazing due to the heat of the oil. You might want to do a search before you go to far down this route.
15th May, 2007 at 12:22:21pm
I agree with Rob, think you might have issues with the brazing.. you dont want the pipe fallling off. |
15th May, 2007 at 12:25:09pm
Brazing will not be a problem, it'll need to get red hot to melt.
15th May, 2007 at 12:26:24pm
i cant see the oil being hot enough to melt good quality solder at all.
15th May, 2007 at 07:57:52pm
I think I saw that thread, I think the person who had made it uses 15mm yorkshire plumbing fittings? The copper Im using Is a lot better qaulity than plumbers copper, wall thickness is also greater, the solder used is high content silver solder, which the melting point is alot higher than the oil temp will ever be. I have used these fittings and solder on refrigeration systems where the discharge (hot gas) temps are a few degrees lower than what you gents are happy to have your oil at. If any one has a query about the strenght of the fitting, when I use them at work, depending on the refrigerant the system uses, we pressure test between 15 and 40 Bar! I have no worries about the materials for the aplication,
![]() 368 Posts Member #: 806 Senior Member Cirencester, Gloucestershire |
16th May, 2007 at 06:31:25pm
hi shaneyboy. thats basically how ive done my except i welded steel pipe on. havent tried it yet though
16th May, 2007 at 11:06:34pm
Its simple but its hopefully fit for purpose.
