| Home > How To > how to remove idler gear bearing in flywheel housing. | |||||||
125 Posts Member #: 751 Advanced Member Aberdeen |
15th May, 2007 at 12:31:55am
I dont have a blind puller and needed to remove my idler gear bearing in the flywheel housing so came up with this method to remove it which took about 5 minutes once i came up witht he idea.
15th May, 2007 at 12:52:36am
there are many ways to do this, each to ther own daniel
15th May, 2007 at 07:16:15am
That's a good tip, nice and simple.
15th May, 2007 at 10:45:15am
i was going to buy a blind puller but cheapest i could find them for was about £50 which is money i could put on my engine rather than a tool id use once.
15th May, 2007 at 10:47:38am
You won't need it only once. You'll need it once a year On 13th Jul, 2012 Ben H said:
15th May, 2007 at 10:52:46am
On 15th of May, 2007 at 10:47am Vegard said:
You won't need it only once. You'll need it once a year ![]() Do you have to replace the idler bearings once a year or is there other bearings needed pulling with it? Daniel |
15th May, 2007 at 12:32:28pm
You get them to last a whole year ...... Every day is a school day ...........
15th May, 2007 at 05:54:20pm
Another way, is fill the bearing with grease, find a good fitting socket, and hit it will a hammer.
Edited by Jason G on 15th May, 2007. On 19th Jan, 2010 wil_h said:
29th Jun, 2014 at 12:57:09pm
idea for people? |
29th Jun, 2014 at 01:32:34pm
Lots of heat and tap the case on the floor, drops out. On 26th Jan, 2012 Tom Fenton said:
29th Jun, 2014 at 08:58:17pm
tried that didn't work for me :( |
29th Jun, 2014 at 10:10:51pm
i have the luxury of a large wood fire pizza oven few min after being sat on the heat bricks in there upside down if fell out with a tap on the back side
7 Posts Member #: 11683 Junior Member |
31st Dec, 2017 at 06:50:16pm
I use a 5kg sliding hammer & ground down washer... Case on ground, feet on case and jerk it hard...
