Home > General Chat > Need help choosing dump valve
jamesfawcett
Member #: 218
Bingley, West Yorkshire
Ive been reading all the posts i can find. My mini will be running 7psi all the time on the mbc, at least until i lower the compression on it.
I hear of problems that people are having wiht the baily piston type (b12 is one of them) and one thing i really dont want what im trying to avoid is unreliability this year. However, i want one that i will be able to use when i up the boost later on in the year. Should i just get a bailys piston one? Are the diaphram ones really that bad?
Nothing wrong with the diaphragm dump valves at all. If you find the standard diaphragm splits just upgrade it to the Kevlar type.
Phil. *smiley*
i have an uprated diahragm type made by forge in glos for some reason its loader than my mates bailey one
jamesfawcett
Member #: 218
excellent wolfie thanks ill look them up
louder
see i can spell when im pissed
mini-marauder
Member #: 68
Coventry
Ive just bought a FMDV002 off ebay cheap, brand new too!
http://www.forgemotorsport.co.uk/products....V&catalog=TUNDV
Sooperdooperturbocooperexpertengineering!
b12
Member #: 247
Kent/Surrey Borders
Feebs ...
My baily Dump Valve is working a charm now ....
It is very loud; and if you back off the revs you can get it to make a contsant sound like air coming out of a balloon
I love it ...
but will probably hate it after a while
GRIN
S
TurboLessTosser
jamesfawcett
Member #: 218
im bidding on one same as your mini-marauder, its only in bradford so only a bus ride away (15 mins max) so ill pick it up and check the diaphram there.
How much did you get yours for?
b12
Member #: 247
Kent/Surrey Borders
my one is a piston type; think it was about ?65
TurboLessTosser
