Home > General Chat > 1 piece to 2 piece... front end ideas.
MarkGTT
Member #: 1194
Shropshire.
Hi all, Has anyone converted a 1 piece fibreglass front end into a 2 piece? Cutting the bonnet out and bracing it etc? thinking of doing this on the clubby as im getting bored of flipping it every time I want to get to the engine. If so do you have any tips / advice? And pics would be great!
Cheers, Mark.
I'm pretty sure Will & Ben did.
Edited by Rob H on 15th May, 2007.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
but why not buy a 2 piece front?
AlexF
MarkGTT
Member #: 1194
Shropshire.
good question*smiley*. The 2 piece front ends don’t have the grill space and lower vents as the original, also my 1 piece fits really well, and loads of work went into getting it spot on.
think i have the mag feature of Will and Bens car so will check that out, but would appreciate their views.
guess i just need to fit a slam panel and a brace across the back
Edited by MarkGTT on 15th May, 2007.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
fair enough reason!
AlexF
vegar
Member #: 189
Where is the best place to gat a plastic front end?? Roundnose btw. I need a new flip front for my new projectvan :)
www.shag.no
www.absmotorsport.net
Badger
Member #: 1488
Dave at tdk- http://www.tdk-racing.com/
Website is down atm, he said it was being updated when I saw him saturday. £80 if I remember correctly for a new 2 piece front.
There is no sense crying over every mistake- you just keep on trying til you run out of cake.
I'm sure my bro will comment further as he did it, not me.
But there is no bracing across the back. What ben did was put some strenghtening olong the bonnet line down the wings, then cut back to this line.
It was a bit of a faf though and the bonnet fitment isn't the best.
I'm getting a two piece clubbie front this summer. I was going to use the standard bonnet and bumper etc. Are you saying this cannot be done?
Ben H
Member #: 184
Melton Mowbray, Pie Country
OK this is how I did it. If I had more time I could do a better job, but it is ok. There is no bracing across the back. Orignially I thought I would need some, but once mounted it is solid on the car. It is a bit floppy off the car, but who cares.
Step 1: Put guides along the bonnet lines. (two bits of wood glassed on)
Step 2: Cover the guides with parcel tape, glass up to them and then remove the guides.
Step 3: While all this is going on make a mold for the A panels and then make some glass a panels. (not necesary if you dont want them)
Step 4: Fit the A panels (the metal is to hold them until the glass is on)
Step 5: Cut out the bonnet and trim it all up. (the cut out bonet is scrap and you will obviously need a propper glass bonnet)
We did this because nobody supplied 2 peice clubman fronts at the time, now people do so I would not do it again unless I happened to get a frontend free or already had one.
Ben
Edited by Ben H on 16th May, 2007.
http://www.twin-turbo.co.uk
bodgeit
Member #: 939
Sorry for the thread hi-jack but did you use an a panel as a mould or make a mould from an a panel?
MAtt
Made a mould from some steel A-panels, then moulded fronm that.
Carl
Member #: 95
liverpool-on-sea
ive just finished fitting my ABS 2 peice fibreglass front.
the original grill fits in no problem.
it has the lower vent shape in, just needs cutting out.
i pretty sure the original clubby bonnet wont fit ill check when i get in.
its the one with built in a panels and its been a real twat to fit. a panels wernt long enough to reach bottom of sill, i had to extend them. the tops of wings were well out of align and needed lots of work. im pretty happy with it now though, but its definatly not a quicjk job to fit.
bodgeit
Member #: 939
Thanks wil_h
MarkGTT
Member #: 1194
Shropshire.
i have used the standard grill with mine, but its not an easy job.. You would need to make brackets for the bumper, but I guess the standard bonnet would fit.
By looking at the pics Ben supplied you get an idea of what you need to cut out etc.
Edited by MarkGTT on 16th May, 2007.
MarkGTT
Member #: 1194
Shropshire.
Big thanks to Ben for supplying the pics thats exactly what i was after! cheers.
Carl
Member #: 95
liverpool-on-sea
heres some pics of mine, it different from the ones in the pics above because it just has a hole rather than a grill moulded in already.
and a pic with a normal bonnet on, its a tiny tiny bit to big i rekon you could get it to fit with a bit of fiddling.
MarkGTT
Member #: 1194
Shropshire.
Carl, the 2 piece looks well made, i would go for that option if i hadnt spent hours.. days.. etc getting mine to fit as i wanted it.
the bit im most worried about is the slam pannel.. looks like i will have to make something. *oh well*
