| Home > Help Needed / General Tech Chat > OT: Problems with lupo | |||||||
![]() 1566 Posts Member #: 36 Post Whore Basingstoke |
16th May, 2007 at 04:59:48pm
Hi All, having issues with the girlfriends car. It's making an odd buzz/grind noise as it goes in to gear. It goes in to gear fine, and the clutch bite point feels normal. I'd guessed at it being a release bearing issue.
16th May, 2007 at 05:25:28pm
I have a lupo! And its wank frankly! Anyway thats besides the point.
16th May, 2007 at 06:56:48pm
Some VW boxes have the release bearing under a cover at the far side of the gearbox meaning that the box doesn't have to come off to change the bearing, worth buying a Haynes manual to find out?
16th May, 2007 at 08:23:43pm
Tom, that's exactly the fault. Screeching and grinding when you press the clutch. Is that likely to be release bearing then?
![]() 263 Posts Member #: 40 Really Very Very Advanced 'Member' Stratford upon Avon |
17th May, 2007 at 08:10:46am
thought id just have a quick serach over on clublupo for u coz used to be a member there when i had my lupo. found a post describing exactly your problem.... then i noticed the member's name |
17th May, 2007 at 09:05:59am
cheers for looking mate, yeah the people on club lupo aren't as forthcoming with info as people on here. I'm guessing you saw the response i got; 'It could be the syncros' hmmm...
17th May, 2007 at 10:17:49am
Sounds like release bearing to me TBH. Does the car do lots of stop start traffic driving? Does your gert sit in traffic with her foot pressed down on the clutch pedal when not moving instead of knocking it into neutral and taking her foot off the clutch? Finally and most importany does she know how to drive without the clutch for when it finally gives up the ghost?!
17th May, 2007 at 10:25:07am
She's only had the car a few months and only done about 2k miles in it, so i doubt most of the damage has come from her.
17th May, 2007 at 10:28:44am
Yep you are about right, won't do it any good, but it will at least get her home if she's stuck somewhere. Ram it in first engine stopped then crank it on starter until it catches and fires, then off you go, trying desperately not to stop if at all possible!
17th May, 2007 at 10:33:57am
Not sure about starting, but to change up you just Almot change like normal except you can't give it to much beans in each gear (basically drive like when you were learning), going down, just let the revs drop fairly lowin gear pull it out of gear give the throttle a little extra and jobs a gooden. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
17th May, 2007 at 10:36:43am
Yep thats about it
17th May, 2007 at 10:37:45am
PS Ric if the release bearing has seized (sounds like it) then it will be wearing into the fingers of the clutch cover, so you'll probably need to put an entire clutch kit in it, not just the release bearing.
17th May, 2007 at 10:40:57am
have you tried clublupo or clubpolo on the net?
17th May, 2007 at 12:17:45pm
i guess it makes to put a complete kit in it anyway if i'm going through the trouble of taking the box off.
Edited by Ric on 17th May, 2007. |
17th May, 2007 at 12:25:54pm
Sounds like you've got what you need, a centreing tool can usually be substituted with an extension bar with some tape wrapped round it.
17th May, 2007 at 12:44:46pm
i have the Lupo GTI |
17th May, 2007 at 01:24:18pm
i used to have a GTI too! i really liked it, alot of fun for a 'senisible' car and quite rare!
20th May, 2007 at 08:48:37am
Update...
21st May, 2007 at 09:51:26am
right, box is off and i've found the problem(s). Bearing is shagged (it's really loose) as expected, but it's taken out the braket thing behind it.
![]() 2102 Posts Member #: 432 Post Whore Swindon |
21st May, 2007 at 09:56:58am
if you have it all off anyway, then i would change it. You dont wanna put it all back together and have to do it again in a few months time..... |
21st May, 2007 at 10:21:56am
well, that's what i thought initially. but i can see the friction plate and it's still got tons of meat on it. Also i don't have a proper centering tool and am worried about getting it back together to find i've done it wrong and need to pull it to pieces again. |
21st May, 2007 at 10:31:23am
Change the clutch buddy.
21st May, 2007 at 10:49:55am
i really didn't want to hear you say that! |
21st May, 2007 at 11:09:41am
You can usually centre the plate by feeling around the edge of the cover at the cutouts with your fingers, and then getting the gap equal all the way round.
21st May, 2007 at 12:16:48pm
i'll buy the socket and have a crack on that tonight then. I can't put the box back on until tomorrow night anyway as vw don't carry stock of the 'sleeve' (not bracket...) i need.
i guess u have already tried that!
