| Home > Help Needed / General Tech Chat > CMS Bolts - with washers? | |||||||
16th May, 2007 at 05:22:06pm
About to start the rebuild of my engine and just wondered wether the centre main strap bolts should be fitted with washers or not?
16th May, 2007 at 06:58:15pm
I don't use washers myself, reason that they might crush and then release clamping on the main cap.
1425 Posts Member #: 690 Post Whore Norfolk |
16th May, 2007 at 08:49:14pm
As Tom says - please do not use washers on anything like mins caps or cylinder heat nuts unless they are proper hardened pieces. The washers you get as std are made of toffee and will yield under the torque application - after a period of time, most likely when they've been heat cycled. Then you are left wit ha bolt with no "stretch" in it and it will come loose. Just make sure the chamfer on the top of the hole is large enough so it doesn't interefere on the radius on the underside of the head on the bolt - otherwise the stress concentration will cause the head to fatigue off. In honesty this is more of a problem on rod bolts.
If Carling made Mini engines
16th May, 2007 at 09:20:51pm
hardened washers for me every time,
17th May, 2007 at 09:40:01am
I'm with carl on this. I'd prefer proper washers. They will only improve calmping issues as the bolt head won't have as much friction when torqued up. On 13th Jul, 2012 Ben H said:
18th May, 2007 at 12:24:41am
When working out axial loads from torques you have to consider the surface friction between the underside of the head and whatever it's contacting. If a washer is present and the diameter is different to diameter of that under the bolt head then you have to pay attention to if the washer rotates against the part or the washer holds against the part and the head of the bolt rotates relative to the washer.
