Home > Help Needed / General Tech Chat > 1st motion bearings, turbo tyoe or standard type.
daniel_johno
Member #: 751
Aberdeen
I have my turbo clutch housing and a standard housing ready to go to the shot blaster for a clean up.
Can i use the standard type with the smaller 1st motion bearing on my tubby engine or is the bigger turbo type needed for reliability? I will be running SC drops so the sideloading will be reduced.
The only reason i ask is i can get a standard one for £11 odd where the bigger turbo type will set me back £50 but if needs must i shall just have to dig deep.
Daniel
you mean the 1st motion shaft roller nose bearing
in short yes no problems there
but if you are building a fire breathing hi boost monster then revert to the original
hope others may comment on their experiences
Lots of people on here have been using the smaller one with success. Do a search, been covered before.
turbo hogster
Member #: 178
stowmaket suffolk
small one every time, the bigger one seems to be a waist of money realy.
mat woods use it and never had probs in tthat particular area
