| Home > Technical Chat > E85 mods | |||||||
20th May, 2007 at 10:19:05am
after one year suspens, it's done . I have a e85 available at the pump!
223 Posts Member #: 598 Senior Member Gaol |
20th May, 2007 at 11:55:39am
Make sure your fuel lines and seals are compatible with the ethanol, it can cause some rubbers to perish or turn to jelly.
On 5th of Sep, 2006 at 05:47pm mini13 said:
I reckon if his brains were gunpowder he couldn't blow his own hat off... |
20th May, 2007 at 12:36:53pm
I have had a read around on E85 compatibility, and there is losts of contradictory info.
20th May, 2007 at 01:15:58pm
about the fuell lines I have polyeth ones, even not satisfied by the diam (5mm inner and 8 mm inner) will use the first for feed and secound for return in a first time, then will upgrade if needed,
14th Sep, 2014 at 09:10:54am
well how has E85 worked out mate?
