Home > Technical Chat > megajolt question about wiring
philc
Member #: 1346
bromsgrove
I am just sorting my wire out on my EDIS unit. Wiring is not my best area so a little help is need.
On the connector wires 1,3 and 4 as you can see in the picture are all joined in the shield should it be separated or left alone. Wires 5 and 6 which are for the trigger are then linked into wires 1, 3 and 4. Does this all need to be separated? thanks *wink*
Edited by philc on 23rd May, 2007.
colas
Member #: 102
Pennsylvania USA
Check here
http://www.autosportlabs.net/MJLJ_V3_vehic..._and_guidelines
t3gav
Member #: 229
Gavin@minispares.com
kent
In the edis 4 pic whats the black loop for that runs to 7 and 9? I assume you dont need saw and pip to get it running?
MrTurbo
Member #: 814
Utrecht, The Netherlands
Indeed you don't need the connection to the MJ (SAW and PIP) to get the system running. Without the SAW and PIP the EDIS unit will run in limp mode (fixed 10degs advance if i'm correct).
The black loop connected to 7 and 9 is connected to the shield of the shielded cable to the VR sensor and the cable to the MJ. The cable to the MJ doesn't really need to be shielded, the cable to the VR sensor does.
t3gav
Member #: 229
kent
Sorry do you mean they should be shielded or physically connected somehow? Cheers
t3gav
Member #: 229
kent
Sorry any ideas, gonna try and fit this at the weekend :) Also whats the maximum distance the vr sensor can be away from the pulley? Cheers
colas
Member #: 102
Pennsylvania USA
I have the sensor less than 1 mm away, so you have to make sure the pully is true. Connect all the sheilded wire together. Thats what I done.
t3gav
Member #: 229
kent
Its one of toms and was brand new so should be fine :). Am i being really thick about this wire i still dont get it *tired*
colas
Member #: 102
Pennsylvania USA
Still don't get what
t3gav
Member #: 229
kent
About the shielded wire, surely its just a cover that goes over it? I dont get what connects to what and what those black lines are all about lol.
colas
Member #: 102
Pennsylvania USA
test
Edited by colas on 28th May, 2007.
The shielded wire has 2 cores within it, and then a braided wire covering around it, this braid protects it from interferance, it should be earthed at the ECU end ONLY.
colas
Member #: 102
Pennsylvania USA
click the link in the above post to see the wiring diagram
t3gav
Member #: 229
kent
But that diagram shows it earthed in conjunction with 7 and 9 neither of which connects to the mj. The shielded cable i got is just black..
colas
Member #: 102
Pennsylvania USA
Put the shield of the wire from the VR sensor and the PIP/SAW wire to pin 7 then split the wire and cannect it to the ground.
t3gav
Member #: 229
kent
Wicked cheers now i get it :)
