Home > Technical Chat > Fitting Zetec squirters
MaltaMini
Member #: 510
Malta
Hi people,
Finally getting down to actually building the engine!
Tried looking through this forum to find anything on fitting Zetec oil squirters into the block, but haven't managed. I'm sure there is something somewhere, so if someone could send me a link, I'ld be grateful.
Otherwise, if someone could give some info, that would be super!
Mark
I donated, but somehow didn't get the label! :(
You must be the worst at searching. I just wrote Zetec in the search window, and had zillions of hits.
Here's a link if your still struggling..
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=5512
Im gonna give this mod a go too, seems cheap, and worth doing for peace of mind. *wink*
And the bling factor!
Just need a glass block so you can appreciate them after fitting. :)
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
Malta Mini,
you are probably having the same problem as I did when I first joined. The default is to search post titles only ... for it to be any use you need to check the box for "search post body".
I was used to forums where this is the default setting, I still believe that it should be but I'm not about to start trouble by suggesting it's changed.
Give that a go.
MaltaMini
Member #: 510
Malta
Thanks lads!
Came up a treat! Sent all the info to Keith (my engine builder) and he's getting a squirter to measure things up.
Hopefuly we start building the engine soon!
Many thanks to everyone for your help!
Mark
i suggest its changed to automatically ticking the box !!lol
