| Home > Technical Chat > 1275 from metro turbo | |||||||
19 Posts Member #: 1612 Member France |
28th May, 2007 at 08:39:35pm
hi guys i've this spec of engine:
Edited by AlexB on 29th May, 2007. |
28th May, 2007 at 10:59:13pm
I am sure that the MG metro chambers are the same volume as the mety turbo 21.4cc so no need for a decomp plate (horrible things anyway .. better getting the head modded).
29th May, 2007 at 08:41:15am
Agree with Roger, what ever you do DONT use a decompression plate...opening a can of worms springs to mind...LOl
29th May, 2007 at 11:40:33am
ok i will try what you say. thanks for help
29th May, 2007 at 11:52:44am
there is no difference between a decomp plate and running with the pistons down the bore as you wants to Matt!:) |
29th May, 2007 at 12:08:45pm
except an extra sealing face to deal with.
29th May, 2007 at 12:32:47pm
André I was think more along the lines of having to use an extra head gasket. Especially when theres other options (like opening the head chambers out) available. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
29th May, 2007 at 03:40:48pm
Decompression plate will also further mess up valve train geometry. Stay away! On 17th Nov, 2014 Tom Fenton said:
591 Posts Member #: 360 Stu from Corwall aka Mr Jazz Piano, Love_Machine, kneegrow |
31st May, 2007 at 12:55:36am
I can't see what's wrong with decompression plates. The name of the game is squish, so if you have the chambers of the plate matched to your head and bowls and use thin gaskets, there should be no problems. Whether you can order one of these or not is up to you to find out. Getting one made is not as awful as it sounds. That's the route I aimed to take but I found that I could scoop out a huge chamber with my die grinder which did the job. Forget inlet valves, you need exhaust flow IMO.
Bugger off, I'm getting there. |
31st May, 2007 at 10:19:00am
how does it mess up geometry on the valve train ?
