Home > Help Needed / General Tech Chat > challenge gearset
fab
Member #: 100
Parisien Turbo Expert
Paris' suburb
I bought last year a st turbo challenge bn gearset,
I've troubles with the 1/2 fork which by touching the secound gear itself doesn't let it engage (the gears are larger than std ones) does I need a special fork, or is a preA+ ones will cure this?
cheers
fab
Yes Fab,
This is a problem on some JK dog boxes as well. You need a fork that is sometimes - but not always - found in Pre A+ cases. I have one I can let you have, but it's a little worn.
There is a guy here in the USA who has had this problem so many times that he purcvhased the equipment and materials to modify A+ forks to get around this problem.
Drop me a PM if you want his details - he'll do you a good price I'm sure if you mention I put you onto him.
fab
Member #: 100
Paris' suburb
Thanks dave!
I've some spares one.
needed to be sure it's the good one.
fab
