| Home > Help Needed / General Tech Chat > megajolt and choke | |||||||
![]() 1252 Posts Member #: 1656 Post Whore stoke-on-trent |
29th May, 2007 at 11:15:04pm
Am I right in thinking that I will still need my choke to warm the engine up when using MJ.
eu gosto de mamas = i like boobs |
29th May, 2007 at 11:29:52pm
Yep.
Edited by Rob H on 30th May, 2007. Isambard Kingdom Brunel said:
30th May, 2007 at 12:07:48am
thank you. just wanted to make sure so i don't mess it up On 23rd Oct, 2009 sim_ou_nao said:
30th May, 2007 at 07:34:30am
i would of thought that the megajolt would have temperature compensation?
30th May, 2007 at 07:35:10am
oh and by the way. i dont bother with the choke on mine but its not a daily driver, if it was then i certainly would be using a choke. |
30th May, 2007 at 09:14:40am
it will be a daily driver i think - hoping the megajolt will make it a bit more reliabel - otherwise i'll just have to get another mini and supercharge it On 23rd Oct, 2009 sim_ou_nao said:
30th May, 2007 at 10:25:20am
The megajolt does not have temperature comp, you have to remember it is a very basic system that does a good job for the money, but it doesn't have all the whistles and bells of omex/emerald etc etc
30th May, 2007 at 11:35:22am
oh right, havent played you see.
831 Posts Member #: 908 Post Whore gateshead |
30th May, 2007 at 10:42:30pm
i find that i use choke, but because the spark is much much better, the engine warms up after about 5 mins running. and the massive amount of fuel that goes into my motor might help too.
balls to the blower!!!
31st May, 2007 at 11:34:15am
when the engine is cold you do not adjust the ignition timing - the engine does not need it.
AlexF |
