Home > Wanted > 8mm T piece - TRIED EVERYWHERE!
jamesfawcett
Member #: 218
Bingley, West Yorkshire
tried EVERYWHERE in keighley for a T piece for the fuel lines, every little motorshop and all the main ones like halfords. I really need an 8mm one the smallest i can find was in motorsave which a guy showed me, it was for the washer jets though!
Anyone got one spare they can sell me, or knoiw a local shop that they could get me one from? Im kind of desperate to get it sorted, and wont mind paying more than what they are worth just to get one !
Might be able to sort you out mate, remind me later!
n.g.l.
Member #: 181
Chard, Somerset
can it be made of plastic? if it can try your local aqurium supplier.
found one for ?3.99 in steel + the vat + the carriage. thats for 5/16" which is as good as 8mm mate! (7.93mm)
That was from www.thinkauto.com
Ill keep looking for a few more.
merlin at combe sell them
jamesfawcett
Member #: 218
only thing is theres a high delivery charge at merlin. Thinking of buying intercooler pipes there though if jimster doesnt sell me his old ones. Tried the aquariums too! They had laods of different sizes, but none over 6mm, it then went to 10mm, 20mm etc
jamesfawcett
Member #: 218
ill check out thinkauto
ill be having a order of silicon hose soon so if you want some stuff let me know.
Ill try get hold of some T pieces as well tomorrow.
jamesfawcett
Member #: 218
great stuff! thanks iain!
I will let you know and ill get it through you.
Arno
Member #: 233
Beugen, Netherlands
Iain, please add 1-off t-piece to my collection of parts too *happy*
Nick
Member #: 154
Midlands
i got mine from a hydraulics company, its a plastic t piece and you push some plastic pipe into it and it bites onto it, rated at 10 bar and is fine with fuel. let me know if you need one, think it was only about a fiver with a metre of the pipe.
jamesfawcett
Member #: 218
Got one, rung my MOT friend in pudsey in leeds. However, two of th elegs are 8mm,but the takeoff is 6mm. Shoul dhte 6mm output be ok for the return?
If it doesnt work, were going to mod the tank.
b and q sell 8 mm t pieces
jamesfawcett
Member #: 218
mine doesnt sell it :( neither does focus, or anywhere! b&q didnt even have the copper 8mm piping that everyone else found in their b&q! just as well though because i got some rubber stuff all the way through now for ?15. I got a MPi tank sorted, getting it tomroow, it has the pump on it and the garage wants ?50 how much do they go for?
b12
Member #: 247
Kent/Surrey Borders
I had heard that putting a t piece in the fuel line is not the way to go ...
now I am only a novice but it kinda makes sense to me ;
if your regulator is trying to pass excess fuel back to the tank, you want as little restriction as possible,
if you t
the regulator has to the force the fuel back into the tank against the pressure of the gravity fed petrol from the tank
Assume a fuel tank of fuel .... thats one HELL of a restriction !
S
TurboLessTosser
nutter driver
Member #: 47
Not very sunny swanage
if your getting a mpi tank, why do you want a t-peice? surely you can just run the return all the way to the back? i understand the t-peice principle, for when people dont want to weld a return into the tank, but if youve already got a return,????
jamesfawcett
Member #: 218
getting the mpi tank now, this thread is old *tongue*
