Home > Help Needed / General Tech Chat > best oil to use
sauber 200
Member #: 245
what oil does everyone use,cheers paul
I use Halfords Semi-synthetic 15w40 in the Mini (Purple can) and Shell Helix Plus 10w40 in the Subaru.
IMO both good oils. I change the Mini every few hundred miles and the Subaru every 6000.
Wil
Soton1310Turbo
Member #: 265
Southampton
I'm usin Valvoline 15W50
Edited by Soton1310Turbo on 2nd Jun, 2004.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
millers classis semi synthetic for transvers engines
superb stuff!
alex
AlexF
Actually that Millers oil is probably the best, I'd forgotton about that. The only reason I don't use it is it's expensive and I can't buy it locally.
Wil
Valvoline Racing 20/50.
Phil. *smiley*
adam1330
Member #: 238
essex
valvoline racing20/50.
jamesfawcett
Member #: 218
Bingley, West Yorkshire
Castrol 20/40 i use
jamesfawcett
Member #: 218
Forgot to ask, but was going to, do i just fill my dashpot up with normal engine oil?
Used to use valvoline 20/50, but got a lot of gear and cam follower wear with it. Now use Ford Super 10/40 - 7 quid a gallon, and seems to have stopped my followers and gear flanks from pitting after only a few thousand miles...
STILL use the valvoline for the dashpot mind!
T3Tone
Member #: 252
Sunny suffolk
Never tried using anything thinner than 20/50 myself so just wondering wot the gearbox feels like with thinner oils????
-MINI CLUBMAN 1380 TURBO-
use valvoline 20/50 for ages and like dave i use to get big wear as you have seen on the follower and every where.
this last year i used Torco 20w50 fully synthetic oiland i thinks its very good but you do pay a price for it, may followers are pitted this year but not as badly.
T3 as for the how the boxes feel i no people do use thinner oils some times, but when ever i've used thiner oils 5w 40 or 5w 50 i have found that the boxes do indeed feel not as smooth, ie they tend to grab like when the baulk rings are worn as your changing gear, be ok for racing i guess as less power loss!
and on a worn engines Ie mine (3000 miles oil) LOL i've found lower oil pressure to with the thinner oils.
pete
Member #: 275
bonie scotland
try using tqf oil, automatic transmision oil for your carb dash pot, used it pullig 8000 no probs
