Home > General Chat > How much primer?
How much primer will I require to do the inside, underside and outside of a bodyshell?
Thanks
I'd buy 3L to start off with and see how you go, you can always buy another litre if you need it, its not like topcoat where you need to buy it all in one go.
Ive used just 3L now on mine and ive primed everything bar the roof so far, ill need another L i recon. Whatr are painting it in?
1380turbo
Member #: 1211
Working up the BHP ladder.
If your using cellulose about 3L should do nicely as it requires thining.
Yes celly, Its just getting a standard respray - probably the only standard thing to go back on though!
I will get an aerosol of white too, for the white stripes that are going up the middle.
