Home > Help Needed / General Tech Chat > Rockers
Anton
Member #: 764
Staffordshire
Ive got the usual later type sindered rocker setup on my engine. Ive got a set of 998 pressed steel rockers in the spares box, both are in decent but used condition.
Which would be better option in your opinion?
Engine is a N/A, Full Race Head. 300deg cam, etc, etc..
Anton
I'd use the pressed steel ones,
I think they are harder wearing due to a better pad and having bushes, also i have heard of sintered ones breaking.
might be worth running a bead of weld up the back of them ala Vizard?
also arn't presed ones higher ratio? 1.3 rather than the 1.25 of sintered ones? or am talking tosh there?
No i think they are 1.3
I always thought that the later cast/sintered (whatever) one were better. I have broken one but only when a spring bound.
johnK
Member #: 690
Norfolk
Anton - 1.5's with the AGSP, you're missing a whole heap of fun without them!
If Carling made Mini engines
miniminor63
Member #: 672
The oversills police
Oslo, Norway
very close to 1.3:1 with the old pressed steel ones (it depends a bit if you have the wide or circular pad). the sintered ones are more like 1.26:1 and the S ones 1.25:1.
graemec
Member #: 1424
Carnforth, Lancs
And I have some 1.5s for sale.... *tongue*
