| Home > General Chat > Quick release poly engine mounts! | |||||||
455 Posts Member #: 1502 Senior Member Aberdeenshire, scotland. |
20th Jun, 2007 at 10:02:51pm
Fitted a set of these today.
20th Jun, 2007 at 10:10:40pm
You think they are a pain when you put the engine in, just wait till you have to take it out. I ended up taking a hacksaw to one of mine. Isambard Kingdom Brunel said:
20th Jun, 2007 at 10:21:34pm
cheers for telling us about them, sorry you had probs with them.
20th Jun, 2007 at 10:26:34pm
Hehe, oh no! Hope they aren't too bad taking them out. Oh well. Think i will go for standard ones next time.
21st Jun, 2007 at 12:06:29am
I've used them a few times, and I found them ok, although it's a good idea to weld a big washer to the pin on them to be able to remove the pin easier Team www.sheepspeed.com Racing
21st Jun, 2007 at 12:16:13am
the secret is not to use the original bolt on the bottom of the 'engine' part of the mount, the original fouls the mating part.
21st Jun, 2007 at 12:51:23am
jimster, thats a decent idea as they are tricky to remove without a mole grips.
21st Jun, 2007 at 10:32:49am
Why are the difficult to remove?? Do the two segments bond together as i am just building up my subby. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
![]() 2102 Posts Member #: 432 Post Whore Swindon |
21st Jun, 2007 at 10:44:16am
i found you have to drop it in at an angle to go in, radiator side first.
21st Jun, 2007 at 01:58:34pm
Yep, takes bloody ages! The guy at Moss warned me about them aswel and said he wouldn't buy them as they were a bugger to fit.lol.
21st Jun, 2007 at 02:33:54pm
Think ill put copper slip on mine they might slide in better. And be easier to remove 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
21st Jun, 2007 at 05:59:08pm
i think simple grease will suffice on the pins "Turbo's make torque, and torque makes fun"
21st Jun, 2007 at 06:03:28pm
Yep I fed mine to the bin monster,
21st Jun, 2007 at 06:25:51pm
On 21st of Jun, 2007 at 12:16am joeybaby83 said:
the secret is not to use the original bolt on the bottom of the 'engine' part of the mount, the original fouls the mating part. Use a button head socket bolt and they work a treat. exactly what ive done, i love mine! had the engine out 3 times so much easier now with no messing about. Also, trimmed a tiny bit of the raised up bit ,just the corners, to make it smooth so it slots in easy. Definately recommend them with a decent bottom bolt Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
21st Jun, 2007 at 11:01:33pm
Right, will do that next time the engine is out.lol. Sounds like they might be quite good once that is done.
180 Posts Member #: 591 Advanced Member Rugeley, Midlands, England |
22nd Jun, 2007 at 05:54:29pm
Just usin std items with captive nuts work well and should be better than the old worn items, was told to stay away from solid mounts
