| Home > Help Needed / General Tech Chat > Not boosting | |||||||
39 Posts Member #: 1195 Member Fort Worth, TX USA |
22nd Jun, 2007 at 10:20:07pm
So I posted a couple weeks ago after my first trip to the RR. I was having fueling issues (way lean under boost). After following the advice I was given I was able to fix a couple of things (pressure was oo high, tear in dump diaphragm, and dashpot oil low). Well all is good there, but when i went back i am now getting no more than 5psi boost and it builds very slowly and hits the 5 at very high RPM. I have an 8psi actuator and on the previous trip was able to run 8+ with no problem and kicked full in at 3500 rpm. . Does this sound like a wastegate/actuator problem, and if so what should I check out? Thanks for the help
23rd Jun, 2007 at 01:06:40am
Is the throttle opening fully?
23rd Jun, 2007 at 02:26:29am
Hi Matt,
23rd Jun, 2007 at 04:16:26am
I am in Mableton, GA. Just outside of ATL. If you could check it out that would be great! Let me know your schedule and we can set something up. Thanks! |
23rd Jun, 2007 at 05:25:53pm
PM m your phone number and address, and I'll see what i can do.
