Home > Technical Chat > PRE A+ gears in A+ Gearbox casing
I realise that the mainshaft in PRE A+ gearboxs is 14mm where it is 18mm in the A+
So when you put the 14mm in the A+ box, youll need the PRE A+ 1st moton bearing for it...
And the rest is just a straight swap?
Thanks
Joe
Yes mate, I have fitted pre A+ to A+ cases no probs. I believe you can put any set in any case.
Paul
fab
Member #: 100
Parisien Turbo Expert
Paris' suburb
for turbo use you'll better keep the 18mm shaft/bearing (your A gears will go on) and buy a pre a+ 18mm first motion.
Paul
Paul
Have a go at fitting an A+ layshaft in an A box, and you'll be surprised *wink*
Everything A 4-sync wil easilty fit in an A+ box, but obviously, use the bits that fit eachother as well.
Hedgemonkey
Member #: 360
Lazy chap here. I picked up a set of 4 synchro SC gears (new) and I'm not sure if they are A+ or A, how do I quickly tell. I havent stripped the A+ box yet to compare and my other A+ bits are buried somewhere.
Cheers, stu
fab
Member #: 100
Paris' suburb
They are A+ ones if it have the longer mainshaft and 18mm roller bearing in the input gear shaft.
Then if it is the shorter mainshaft and 14mm roller B it's a pré A+ one.
fab!!! :)
Haha nearly 3 years to have his question answered! *hehe!*
fab
Member #: 100
Paris' suburb
It's better later than never!
You coming to Avon this year fab?
fab
Member #: 100
Paris' suburb
not sure yet that's around my head,
still having headhackes just thinking about last year sunday though :-
man up and come over!
fab
Member #: 100
Paris' suburb
!:nbvcx,
mini's bonnet opened!!!
