Home > Help Needed / General Tech Chat > What size fuel lines are you running? (turbo mini's)
UEV409K
Member #: 1706
WILTSHIRE
Just out of intrest, what size fuel lines are you running from tank to the carb?
5mm0 Votes 0 Votes - 0%
6mm0 Votes 0 Votes - 0%
7mm0 Votes 0 Votes - 0%
8mm11 Votes 11 Votes - 85%
9mm0 Votes 0 Votes - 0%
10mm2 Votes 2 Votes - 15%
Nick
Member #: 154
Midlands
i'm running
tank to pump - 10mm
pump to reg - 8mm
reg to carb - reduces from 8mm to 6mm
return - 10mm
if it helps at all.
neilj1678
Member #: 1297
Sunny Stockport
Don't have a carb but 10mm od copper tube everywhere
Richie
Member #: 628
on average most use 8mm feed and return, however i am running 8mm feed and 10mm return there was a good discussion on this topic if you use the search engine it should give you a good bit info *wink*
Richie
TRADER HALL OF FAME
TRADERS OF SHAME
1 user....pm me 4 details
LEGENDS
MikeRace, Mini13
