| Home > Help Needed / General Tech Chat > dump valve | |||||||
26 Posts Member #: 1798 Member Ratingen (Germany) |
2nd Jul, 2007 at 12:42:51pm
does anyone know what happens to a dump valve?
2nd Jul, 2007 at 12:51:26pm
if its a piston type then you may have to clean it and grease it, but it wont last long. the solution is to fit the vacum pipe at the bottom to stop the build up of fuel etc.
2nd Jul, 2007 at 01:00:27pm
it is a piston type and i have already given it a good clean and lube (coperslip?) ill change the pipe over and see if its a leak |
2nd Jul, 2007 at 01:01:40pm
Have you checked that your definitely making boost? https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
2nd Jul, 2007 at 01:36:14pm
good point about it making boost in the first place.
Edited by Turbo Shed on 2nd Jul, 2007. |
2nd Jul, 2007 at 01:38:21pm
Have you blocked off the poppet valve in carb butterfly?
2nd Jul, 2007 at 01:57:07pm
Hi All,
2nd Jul, 2007 at 02:20:10pm
piston ones are good if you fit them properly |
2nd Jul, 2007 at 04:22:30pm
It will not open properly if the poppet valve in the butterfly is still there, you need to get a plain butterfly or block the hole somehow.
2nd Jul, 2007 at 04:30:22pm
Tom, are you sure about the poppet valve?
2nd Jul, 2007 at 04:33:23pm
thinking of things.....
4th Jul, 2007 at 09:45:29am
my dump valve i cant adjust but im thinking its a damaged pipe
