Home > Help Needed / General Tech Chat > rev counter not working
Gilly2006
Member #: 1720
Bamber bridge, Preston
just bought my new mini the other day, and the rev counter doesn't work, could anyone tell me what could be the cause of the problem? would the cable have gone?
err, no. The rev counter will be electronic. Is it a standard (i.e. Austin/ Rover fitted) or after market?
It will have 3 wires, +12 V, Earth and signal. The standard wiring for a later mini is white/black for the signal and this should be connected to the negative of the coil.
The rev counter could be broken of course, the later ones can be fragile.
miniminor63
Member #: 672
The oversills police
Oslo, Norway
there are mechanical ones too, but I doubt its one of those, so listen to Will's suggestion.
Gilly2006
Member #: 1720
iv got a mini 25 if that helps, and the clocks are standard. not aftermarket ones. he did say it has worked its just abit tempremental.
Turbo Shed
Member #: 30
Epsom, Surrey
did the 25 come with a rev counter? i thought the 25 was a poverty spec mini.
stefaz
Member #: 1656
stoke-on-trent
25 was a low spec, but the 25 le did have a rev counter - first mini to have 8.4" disks too. check the connectors on the back mate - needs to be properly on otherwise it wont work too well if at all
