Home > Technical Chat > Beak or De-Beak
I was intruiged by this photo in the latest minimag:
It is supposed to be a picture of the damage to Calvers state of the art N/A 1330 engine.
What intruiged me was that he appears to be running a de-beaked combustion chamber.
So is there an advantage to this mod as well as lowering compression?
Ask TD he's bumming David Vizzard!!
As far as I'm aware, Viz always kept a beak, although sometimes only minimal.
Wil, is your latest head de-beaked?
No, the current head has a beak; but all previouse heads have had the beak removed.
To get low enough CR on a 1275 for a turbo you need to remove it, but on a 998 it can be kept.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
what is beak & de-beak?
On 19th Jan, 2010 wil_h said:
Top beaked, bottom de-beaked:
miniminor63
Member #: 672
The oversills police
Oslo, Norway
there are 1275 turbo heads with low compression and the beak still in place...
Yes, but I've not seen a de-beaked chamber on a full race N/A 1275.
But then I've lived a sheltered life.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Thanks Axel. So a de-beaked will give lower compression if my logic makes sense. Beaked version with deeper dish in piston will give same compression?
Edited by Jason G on 5th Oct, 2008.
jason,
as I understand it, the spark plug starts a fire, this burns across the chamber to the other side, the "beak" "spreads" the fire to help it get to all the corners of the chamber quicker/better giving a mre complete burn.
state of the ark!
my mate had loads of beak at uni, never been the same since..
_DAN_
Member #: 1819
How does the idea of that beak causing a hot-spot and creating det stand up nowadays?
seems not to be an issue.
On 6th of Jul, 2007 at 07:10pm mini13 said:
jason,
The beak mostly affects swirl. This makes the cylinders fill easier= more hp.
Also it helps squish area.
I had 7.5:1, and a std, but smoothed chamber...
Wouldnt say my pistons were top spec to to achieve a low CR.
I would never remove the beak, and destroy what is quite a good combustion chamber shape.
Its that shape for a reason.
pristic
Member #: 1774
Sydney AUS
Running unleaded fuel on a 'leaded' head with beaks youll get massive wear in the seats. If its de-beaked then your not going to get the same wear problems.
Thats the way I understand it. In big bores its not so much an issue. With 998 and 1100 heads it makes much more difference.
1132cc Turbo ~120 bananas ATW - Fun Fun Fun
miniminor63
Member #: 672
Oslo, Norway
I didn't understand that either
Can you elaborate on this ?
Because what you said, makes no sense to me whatsoever, and it seems a couple of other people.
the shape of the chamber has nothing to do with valve seats and valve seat wear whatsoever.
He's talking about the valve guide boss, I think!
Jason G
Member #: 1459
En-suite user
Braintree, Essex
I understand swirl. Never heard the term beak before. I'm having another alchohol fueled dim wit moment. cheers anyway m8 :)
pristic... surely if running unleaded in a leaded motor you use additives etc.
Either way...I thought thats a valve & guide issue also.
jason,
Edited by Jason G on 10th Jul, 2007.
Pristic. Lay off the Stella please. You're talking shite!
LOL @ V !*laughing*
I think we all understand that lol
